March 9, 2010, 09:42 |
Parallelization with icoFsiFoam
Wolfgang W.
Rep Power: 17 |
Hello Foamers,
I have a problem which might be very simple to solve - or very tricky. I'm working with icoFsiFoam on OpenFoam-1.5-dev. So far i was quite content running the solver on my 1-core PC but as usual cases grow larger and more complex so finally I'm trying to perform the calculations on a computing cluster. I did some preliminary tests using more basic solvers to learn about decomporsePar and reconstructPar / reconstructParMesh. So far, everything is fine and the cluster does a great job. Now, the focus of my work is on FSI, thus I use icoFsiFoam. And here I ran into some problems with the decomposition for the parallelization. As I have two distinct mesh regions (fluid, solid) I'm basically not sure how to perform the decomposition in general. Shall I decompose both regions into let's say 6 SubDomains? or decompose only the fluid region? (I tried both without success). And how many processors do I need to assign to the task? The sum of solid and fluid subdomains? I assume there is an elegant way to get this right, but I'm a little bit lost. I would very much appreciate any help you could provide on that issue. Best regards, Wolfgang |
parallelization calculation | SARU | OpenFOAM | 0 | December 15, 2009 20:24 |
icoFsiFoam case needed | vivekcfd | OpenFOAM | 1 | May 6, 2009 14:41 |
IcofsiFoam not supported under released 141 package | pi06jl6 | OpenFOAM Running, Solving & CFD | 4 | June 26, 2008 14:59 |
Solid Large deformation for icoFsiFoam | fw407 | OpenFOAM Running, Solving & CFD | 2 | June 13, 2008 11:58 |
Errors in running a icoFsiFoam case | jin_xu | OpenFOAM Pre-Processing | 0 | June 9, 2008 07:48 |
