mass flux and temperature b.c with cyclic conditions |
March 5, 2010, 06:14 |
David
Rep Power: 16 |
Hi to all
I want to simulate a scraper surface heat exchanger which consists in a circular duct with scrapers inserted inside it. Im using cyclic conditions to simulate only one pitch between scrapers but I need to fix the mass flux, not the velocity. Can anyone explain how to do that? Also Im applying a constant heat flux on the walls, and the inlet and outlet temperature has also cyclic condition, I don't know if it is correct. Thankyou very much in advance for your attention David |
Wind turbine simulation | Saturn | CFX | 60 | July 17, 2024 06:45 |
How to set a initial temperature and constant heat flux at same BC's?? | Jane | FLUENT | 4 | October 25, 2015 13:01 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 05:05 |
Concentric tube heat exchanger (Air-Water) | Young | CFX | 5 | October 7, 2008 00:17 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 16:55 |
