How to open a new case
Old   March 2, 2010, 11:23
Question How to open a new case
Sandu69 is on a distinguished road
Hello!
I'm an openfoam beginner and have the following question:
Is there any way to open a new case without copying one from any tutorial or other old case?
I mean so that the basic structure is given?
Thanks for your help,
best regards,
Sandu69
Sandu69 is offline   Reply With Quote
Old   March 2, 2010, 12:25
sega's Avatar
Sebastian Gatzka
sega is on a distinguished road
Originally Posted by Sandu69 View Post
Hello!
best regards,
Sandu69
Unfortunately not.
You have to write the files for yourself or alter the exisiting tutorial cases.
Schrödingers wife: "What did you do to the cat? It's half dead!"
sega is offline   Reply With Quote
Old   March 2, 2010, 13:12
All right, I was afraight of this answer.
But thanks, let's start programming...
Best wishes,
Sandu69
Old   March 3, 2010, 03:48
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
Hello!
Not directly, but there are ways to solve the problem.
From foamCopySettings -help:
Usage: foamCopySettings srcDir dstDir
    Copy OpenFOAM settings from one case to another, without copying
    the mesh or results.
    - requires rsync
Note
    The foamCopySettings.rc (found via the ~OpenFOAM expansion - see foamEtcFile)
    can be used to add any custom rsync options.
Another possibility (which we use) is to create templates of settings for various applications, store them centrally, and then create new cases from these templates (again using rsync).
We store them in the $WM_PROJECT_INST_DIR/site/templates directory, but they could potentially also use the ~OpenFOAM mechanism.
olesen is offline   Reply With Quote
Old   March 3, 2010, 11:37
Thanks for your advice, that sounds to be a good solution :-).
new case, open, openfoam
Open Channel Boundary Conditions via journal Matteo FLUENT 0 January 21, 2008 12:05
Could the CFD community benefit from Open Source? JF Main CFD Forum 13 December 18, 2006 00:06
opening ensight case in open source visualizer clhona Main CFD Forum 13 December 15, 2006 18:59
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 13:24
where to open the file jx FLUENT 0 February 19, 2004 13:19
