February 26, 2010, 13:35 |
New solver guides
Alberto Passalacqua
Rep Power: 36 |
I have recently put on the wiki two new guides
More will come in some time, with the idea of documenting at least the fundamental main solvers. Of course comments, tips, and reports on mistakes are welcome! Best,
Alberto Passalacqua GeekoCFD - A free distribution based on openSUSE 64 bit with CFD tools, including OpenFOAM. Available as in both physical and virtual formats (current status: http://albertopassalacqua.com/?p=1541) OpenQBMM - An open-source implementation of quadrature-based moment methods. To obtain more accurate answers, please specify the version of OpenFOAM you are using. |
February 27, 2010, 22:58 |
Darrin Stephens
Rep Power: 17 |
Alberto, thanks for adding these new guides to the wiki. In the bubbleFoam description you refer to the phase-intensive formulation of the phase momentum equations proposed by Weller. Do you have a copy of this reference or know where I could get a copy?
February 27, 2010, 23:26 |
#3 | |
Alberto Passalacqua
Rep Power: 36 |
The phase-intensive formulation is a way to manage the problem of the singularity in the momentum equation when the phase fraction becomes zero. If you expand the time derivative and the convective term, so to rewrite the momentum equation in non-conservative form, you can then divide the equation by the phase fraction. In such a situation, you only have one term that could give problems, since the phase fraction has been removed from all the other terms. This term is in the form grad(alpha)/alpha, which is assumed to be well behaved when alpha -> 0. Of course the price you pay is that the momentum equation is resolved in non-conservative form (see the papers from Jeong). Work is (slowly, it's not my primary activity ) in progress to have a code with the conservative form of the equations. Best,
March 1, 2010, 06:10 |
Niels Gjoel Jacobsen
Rep Power: 37 |
Hi Alberto
Congratulations on making your rather extensive work public. At a first glimpse it looks as an exhaustive description. Best regards, Niels |
March 9, 2010, 08:20 |
Aniko Rakai
Rep Power: 17 |
Hi Alberto, thanks a lot for pushing it to the wiki. Especially the part about IOdictionary was very useful to me. And the structure is great if I download in pdf.
March 9, 2010, 12:39 |
Francois Beaubert
Rep Power: 17 |
Thanks Alberto for your impressive work !
March 9, 2010, 16:50 |
#7 | |||
as I wrote you after the launch of The FOAM Documentation Project: Thanks a lot for all the work and effort you have put on documenting these top-level solvers. I think it is really awesome work that really should be made available for the community! Quote:
best, Holger
Holger Marschall web: http://www.holger-marschall.info mail: holgermarschall@yahoo.de |
March 10, 2010, 13:13 |
Alberto Passalacqua
Rep Power: 36 |
Hi Holger.
Of course if a more organized project will be created/come back, as I hope, everything I write can be easily re-used/adapted. In the meanwhile, I hope the wiki pages are of some help, especially to new users. Best,
Wiki solver guides | alberto | OpenFOAM Announcements from Other Sources | 21 | March 28, 2012 23:02 |
Working directory via command line | Luiz | CFX | 4 | March 6, 2011 21:02 |
why the solver reject it? Anyone with experience? | bearcat | CFX | 6 | April 28, 2008 15:08 |
compressible two phase flow in CFX4.4 | youngan | CFX | 0 | July 2, 2003 00:32 |
Setting a B.C using UserFortran in 4.3 | tokai | CFX | 10 | July 17, 2001 17:25 |
