Error will loading makeAxialMesh utility in openFOAM-1.6 |
October 21, 2014, 05:48 |
#21 | |
Mahdi
Rep Power: 13 |
I do agree with your opinion, because I am not an Ubuntu fan neither Finally, I found the right package, it is "libiberty-dev", now it works well, it is interesting that in none of the posts, this package was named By the way, another minor question, when using makeAxialMesh, is it only possible to set one of the boundaries as the symmetry line or also an external line (like an axis)? This gets important in the case of annular channel model. Thanks and Best, Mahdi |
October 21, 2014, 06:16 |
#22 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request |
Sample Utility not working in OpenFoam 1.6 | titio | OpenFOAM Post-Processing | 6 | November 15, 2014 19:04 |
problem with sampling Utility in openFOAM 1.6 | carmir | OpenFOAM Post-Processing | 10 | February 26, 2014 03:00 |
Sample Utility not working in OpenFoam 1.6 | titio | OpenFOAM Post-Processing | 0 | February 5, 2010 13:12 |
Cross-compiling OpenFOAM 1.6 on Linux for Windows 32 and 64bits with Mingw-w64 | wyldckat | OpenFOAM Announcements from Other Sources | 7 | January 19, 2010 16:39 |
OpenFOAM Version 1.6 Released | opencfd | OpenFOAM Announcements from ESI-OpenCFD | 0 | July 27, 2009 18:55 |
