janafThermo: How to read formula? or at least: How to use hPolynomialThermo? |
February 22, 2010, 15:17 |
Benedikt Goeppner
Rep Power: 16 |
Hi everybody,
I'm simulating a nozzle with OpenFOAM. When using a constThermo-modell the simulation ends with "maximum number of iterations exeeded"-exeption for the thermodynamic model so I was thinking of using some variable heat-capacity-setting like janaf or polynoms. But how do I have to understand the formula for the janaf-model that is given in the user-guide (http://www.openfoam.com/docs/user/th...37-2040007.1.1)? In the biconic25-55Run35 tutorial from rhoChentralFoam there is a thermodynamic model using janaf-coefficients for N2. Unfortunately if I put those coeffs into the in user-guide provided formula for calculating heat-capacity from janaf-coeffs the function does not even behave like the experimental data (e.g. http://www.engineeringtoolbox.com/nitrogen-d_977.html)... Instead of rising with temperature the heat-capacity is lowering? The search-function didn't lead to any results... Am I missing something? Are the coeffs in the tutorial wrong? Am I taking the wrong formula? And by the way: How can I use the polynomial-model? In the user-guide there is only a link to a tutorial. I cannot find a word about hPolynomialThermo there (even if it obviously uses some polynoms... for heat-capacity as well as for some other vars...) Thanks in anticipation for any suggestions or explanations! Ben |
problem when converting mesh (made by ICEM) using fluentMeshToFoam | Forrest_Lei | OpenFOAM | 11 | October 16, 2009 06:28 |
Phase locked average in run time | panara | OpenFOAM | 2 | February 20, 2008 14:37 |
how to read a gridpro 2d file into starcd shell | prc | Siemens | 3 | December 21, 2006 18:59 |
Error Fluents | TDL | FLUENT | 6 | April 26, 2005 06:02 |
Benetton Formula 1 | CD adapco Group Marketing | Siemens | 13 | February 7, 2002 09:33 |
