reference area
Old   February 13, 2010, 08:53
Default reference area
Andrea Pasquali
andrea.pasquali is on a distinguished road
Is there in OF a code to calculate the frontal area "Aref" (for example the car frontal area) to calculate Cx and Cz using "forceCoeffs" function?
Thanks,
Andrea
Andrea Pasquali
andrea.pasquali is offline   Reply With Quote
Old   February 14, 2010, 10:33
Default liftDrag
Andrea Pasquali
I found "liftDrag" application for OF1.4.
I try to compile it on my OF 1.6.x without success...
Does any version exist for OF1.6 or 1.6.x ?
Does this application calculate the frontal area "Aref" ?
Thanks for any help!
Andrea
Andrea Pasquali
Old   May 5, 2010, 11:41
louisgag's Avatar
Louis Gagnon
louisgag is on a distinguished road
Send a message via ICQ to louisgag
Hi Andrea,
I am also looking for a way to easily calculate the frontal area of a complex 3D body. So far, it seems the only way to do it would be to sum the (area vectors dot the normal vector) on a whole physical surface and ignore negative values (to avoid having a zero total area!).
The code involved would look something like
mesh.Sf().boundaryField()
but I don't have time to do it at the moment.
and a loop like
forAllConstIter(labelHashSet, patchSet_, iter)
I'm just inspriring myself from the forces code....
Best regards,
-Louis
louisgag is offline   Reply With Quote
Old   May 17, 2010, 21:13
Lightbulb
louisgag's Avatar
Louis Gagnon
I have looked into it some more and here's the exact command that will give you the frontal area (in x-direction)...
Info << "***********" << ( sumMag(Sfb[patchi].component(vector::X))/2 ) << "***************" << endl;
I'll get back with an actualy utility for this if I find the time to make one,
-Louis
EDIT: that formula only works if the part has no concavity (ie: holes inside) because this would count areas that should not be counted...
Old   June 10, 2010, 03:20
Björn Bergqvist
bjornthe is on a distinguished road
in the meantime, just do like this:
http://www.discretizer.org/node/20
Björn
________________________________________
Björn Bergqvist,
creator of Discretizer,
a free mesh generator for OpenFOAM
_________http://www.discretizer.org_____________
bjornthe is offline   Reply With Quote
Old   August 4, 2010, 17:55
louisgag's Avatar
Louis Gagnon
thanks for this very useful link. Just a note, if your shape contains some concavities you need to select cells through (or actually skip the extract selection step) and then divide the final result by two.
Cheers,
-Louis
Old   August 5, 2010, 05:31
NAVEEN.K.M
naveen is on a distinguished road
hi louisgag,
Total area can be calculated using the liftdrag utility in OpenFOAM 1.4.1 by running liftDrag and put the same area at the end of controlDict of OpenFOAM 1.6....
Regards,
Naveen
naveen is offline   Reply With Quote
Old   August 5, 2010, 14:00
louisgag's Avatar
Louis Gagnon
Thanks Naveen.
Error with Wmake skabilan OpenFOAM Installation 3 July 28, 2009 01:35
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 20:08
CFX Solver Memory Error mike CFX 1 March 19, 2008 08:22
G95 + CGNS Bruno Main CFD Forum 1 January 30, 2007 01:34
Building OpenFoAm on SGI Altix 64bits anne OpenFOAM Installation 8 June 15, 2006 10:27
