wallHeatFlux utility in OpenFoam1.6
Like Tree3Likes
Old   April 20, 2011, 11:33
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
hmm ... don't know.
but i think that's a problem, couse you can not decline some thermophysicalProperties for a solid. Just for fluids you can declare it.
good question.
I 'm trying on a case today afternoon (chtMulti) with one fluid and solid region. Hope i can calculate the wallFlux with the post tool.
i ll give an replay about it.
see you later.
Tobi
Tobi is offline   Reply With Quote
Old   April 21, 2011, 06:36
Tobi's Avatar
Tobias Holzmann
Question:
how did you successful start wallHeatFlux on the fluid region?
you put every file into another folder or? And generate a "virtual" case for you post tool?
-> i did a simulation yesterday with one fluid and solid region. Solved it an put every fluid file in another folder. After using wallHeatFluxLaminar i got those message:
--> FOAM FATAL IO ERROR:
Unknown patchField type compressible::turbulentTemperatureCoupledBaffleMixed for patch type directMappedWallValid patchField types are :
42
advective
buoyantPressure
calculated
cyclic
directMapped
directionMixed
then i changed the patchField type to directMapped with the tool changeDictionary.
After that i got the message
--> FOAM FATAL ERROR:
compound has already been transfered from token
    on line 20 the empty compound of type List<scalar>
    From function token::transferCompoundToken()
    in file lnInclude/token.C at line 95.
FOAM aborting
How did you get your wallHeatFlux in you fluid region?
Did you use another wallHeatFlux - post Tool?
regards Tobi
Old   April 21, 2011, 10:39
Nicolas
NicolasB is on a distinguished road
I've tried the wallHeatFluxRho utility from a previous post in this thread, and I've copied all files from fluid zone to a new directory (0, 5000, constant, system) in which I use the utility.
Hope this helps you.
NicolasB is offline   Reply With Quote
Old   April 21, 2011, 10:48
Tobi's Avatar
Tobias Holzmann
sure, ... i 've tried it with that tool, too.
What 's your T - File ?
can you post it ?
Thx Tobi
Old   April 22, 2011, 14:32
Nicolas
Hi Tobi,
Since I'm not at the office, I haven't got the needed file. However, I've posted my case here (if you have any hint on this subject, I'd be glad to have your advice )
Regards
Old   April 27, 2011, 04:36
Tobi's Avatar
Tobias Holzmann
Hey Nicolas,
short question. Did you get the wallHeatFlux calculated at the surfaces:
" fluid_air_to_solid_cable " and " fluid_air_to_solid_beton ".
Tobi
Old   April 27, 2011, 08:14
Nicolas
Here is what I get in the console:
caelinux@caelinux-desktop:~/OpenFOAM/caelinux-1.7.0/Freyssinet3/air$ wallHeatFluxRho
|  \\    /   O peration     | Version:  1.7.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.com                      |
Build  : 1.7.0-113391ee57bd
Exec   : wallHeatFluxRho
Date   : Apr 27 2011
Time   : 13:11:10
Host   : caelinux-desktop
PID    : 25175
Case   : /home/caelinux/OpenFOAM/caelinux-1.7.0/Freyssinet3/air
nProcs : 1
SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE).
Create time
Create mesh for time = 0
Time = 0
Selecting thermodynamics package  hPsiThermo<pureMixture<constTransport<specieThermo<hConstThermo<perfectGas>>>>>
Selecting RAS turbulence model laminar
Wall heat fluxes [W]
fluid_air_to_solid_cable 0
fluid_air_to_solid_beton 0
Time = 5000
fluid_air_to_solid_cable -981.77797
fluid_air_to_solid_beton -1298.0191
End
NB: I work with OF 1.7.0
Nicolas
Old   August 8, 2011, 04:53
Ishan
ishaninair is on a distinguished road
Hi Ulrich Heck,
I did the same thing as told by you. But I am getting following error -
Time = 0
Selecting thermodynamics package ePsiThermo<pureMixture<sutherlandTransport<specieT hermo<hConstThermo<perfectGas>>>>>
Not implemented
From function basicThermo::h()
in file basicThermo/basicThermo.C at line 259.
FOAM aborting
#0 Foam::error:rintStack(Foam::Ostream&) in "/home/ishan/OpenFOAM/OpenFOAM-1.7.1/lib/linuxGccDPOpt/libOpenFOAM.so"
#1 Foam::error::abort() in "/home/ishan/OpenFOAM/OpenFOAM-1.7.1/lib/linuxGccDPOpt/libOpenFOAM.so"
#2 Foam::basicThermo::h() in "/home/ishan/OpenFOAM/OpenFOAM-1.7.1/lib/linuxGccDPOpt/libbasicThermophysicalModels.so"
in "/home/ishan/OpenFOAM/OpenFOAM-1.7.1/applications/bin/linuxGccDPOpt/wallHeatFluxRho"
#4 __libc_start_main in "/lib/tls/i686/cmov/libc.so.6"
Aborted
Please Help
Regards,
Ishan
ishaninair is offline   Reply With Quote
Old   August 9, 2011, 16:12
Default Wallheatfluxrho
  #29
Ishan
I tried solution given above for calculating heat flux in rhoCentralFoam. But it gives following error-
Create time
Time = 0
Not implemented
FOAM aborting
Aborted
Please Help!!
Regards,
Ishan
Old   October 3, 2011, 11:43
Default convective heat transfer?
  #30
maddalena's Avatar
maddalena
maddalena will become famous soon enough
Hello everyone,
I would like to have the convective heat transfer on a wall patch. Following from the definition: alpha = wallHeatFlux / (T_wall-T_ref). This can be obtained with the use of ParaFoam, see here. What about if I modify wallHeatFluxLaminar in order to calculate alpha at the end of my simulation? This is what I would do:
forAll(wallAlphaCoeff.boundaryField(), patchi)
                wallAlphaCoeff.boundaryField()[patchi] =
                    wallHeatFlux.boundaryField()[patchi]
                        /(T.boundaryField()[patchi] - Tref);
where:
dimensionedScalar Tref
transportProperties.lookup("Tref")
However, this has two main problems:
  1. OpenFOAM complains about the T.boundaryField()[patchi] - Tref implementation. It does not like the - operator, but how should I write it?
  2. If I will have a division by zero. Thus I should add something like:
if T.boundaryField()[patchi] == Tref
      wallAlphaCoeff.boundaryField()[patchi] = 0.0;
else
Of course, this is not written in a correct way. Is there anyone that can help me to understand what I am doing wrong?
mad
maddalena is offline   Reply With Quote
Sample Utility not working in OpenFoam 1.6 titio OpenFOAM Post-Processing 6 November 15, 2014 19:04
problem with sampling Utility in openFOAM 1.6 carmir OpenFOAM Post-Processing 10 February 26, 2014 03:00
How to compile a new utility rudy OpenFOAM 4 October 1, 2011 23:48
wallHeatFlux BC not constant after restart eelcovv OpenFOAM Running, Solving & CFD 26 May 25, 2011 00:11
Sample Utility not working in OpenFoam 1.6 titio OpenFOAM Post-Processing 0 February 5, 2010 13:12
