averaging in les
Old   February 5, 2010, 04:21
Default averaging in les
Kapa Lilla
klilla is on a distinguished road
Dear All,
I made a compressible LES simulation and used the averaging function to get the mean and r.m.s. pressure. A bit disturbing, but the r.m.s. pressure contains negative values in some cells. How can this be?
Thanks,
Lilla
klilla is offline   Reply With Quote
Old   February 9, 2010, 05:02
Eugene de Villiers
eugene is on a distinguished road
I don't think the Prime2Mean values are being calculated in the way you think, i.e
Field_rms = sqrt(Mean(sqr(Field-FieldMean)))
Remember, this is a running average, so the initial value for FieldMean is not accurate. As a result the mean squares are calculated as:
Field_ms_new = alpha * Field_ms_old + beta*sqr(Field) - sqr(FieldMean_old) + sqr(FieldMean_new)
where alpha = (N-1)/N and beta = 1/N, which can lead to negative values for small N.
It could also happen, that you restart the calculation with a FieldMean present, but with no Field_ms. This could lead to large initial negative values, as the initial Field_ms is calculated as:
Field_ms_init = sqr(Field) - sqr(FieldMean)
A better initialisation would probably be:
Field_ms_init = sqr(Field - FieldMean)
eugene is offline   Reply With Quote
Old   February 10, 2010, 03:29
Kapa Lilla
Dear Eugene,
thanks for your answer. Indeed, I checked the implementation as well, and the problem can arise from my test case. I have a pulsating source around a constant flowfield. The source term I guess makes harder to compute the mean, so I decided to fix the mean flow by myself and than calculate p^2 for noise computation.
Best regards,
Lilla
spanwise averaging for LES backward facing step Sungho Yoon CFX 6 July 23, 2008 11:34
Averaging LES iko FLUENT 3 July 3, 2008 06:55
Start of averaging in LES fab Main CFD Forum 2 June 16, 2005 05:53
Some Questions about LES. Bin Li Main CFD Forum 2 February 20, 2004 10:58
Averaging Method for LES Kim Main CFD Forum 0 November 21, 2001 08:18
