SimpleFoam : LowRe vs Wall Functions
Old   February 3, 2010, 15:41
Default SimpleFoam : LowRe vs Wall Functions
Gearb0x is on a distinguished road
I'm currently trying to run a simpleFoam case with & without the use of wall functions.
The problem is : I fix the pressure drop to match a certain mass flow. Here I fix it to 30 so : p_inlet = fixedvalue 30, p_outlet= fixedvalue 0
The simulation seems to run fine on one geometry but not on the other and I don't understand why...
The two geometries are : One with "short legs" (see pictures below) and one with "long legs" to have a developed flow.
The geometry with short legs give the same results with the LowRe model (without wallfunction) and the HighRe model (with wallfunctions) :
Pfield without wallfunction (LowRe)
http://yfrog.com/iypressurefieldp
Ufield without wallfunction (LowRe)
http://yfrog.com/i3velocityfieldp
Pfield with wallfunction
http://yfrog.com/jvpressurefieldp
Ufield with wallfunction
http://yfrog.com/i3velocityfieldcp
Whereas the geometry with long leg gives weird results (numerical values & flow geometry) for the pressure with the two models :
Pfield (LowRe)
http://yfrog.com/3mpressurefieldp
Ufield (LoweRe)
http://yfrog.com/58velocityfieldp
Pfield(HighRe)
http://yfrog.com/58pressurefieldp
Ufield(HighRe)
Can someone give me a hint where I could go wrong with my simulation and why do I get such changes from just changing the geometry?
Thank you very much.
Gearb0x is offline   Reply With Quote
Old   February 4, 2010, 06:02
Thomas Baumann is on a distinguished road
Hi GearB0x,
could you upload your boundary conditions? Espacially what are your velocity bc's at the inlet and outlet.
Regards Thomas
Thomas Baumann is offline   Reply With Quote
Old   February 4, 2010, 09:55
Here are my Boundary Conditions for the LowRe model (without wall functions) :
For p :
dimensions      [0 2 -2 0 0 0 0];
internalField   uniform 0;
boundaryField
    inlet
        type            fixedValue;
    value        uniform 30;
    outlet
        type            fixedValue;
        value           uniform 0;
    fixedWalls
        type            zeroGradient;
    frontAndBack
        type            empty;
For u :
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 0 0);
boundaryField
    inlet
        type            zeroGradient;
    outlet
        type            zeroGradient;
    fixedWalls
        type            fixedValue;
        value           uniform (0 0 0);
    frontAndBack
        type            empty;
For nut :
dimensions      [0 2 -1 0 0 0 0];
boundaryField
    inlet
        type            calculated;
        value           uniform 0;
    outlet
        type            calculated;
        value           uniform 0;
    fixedWalls
        type            zeroGradient;
    frontAndBack
        type            empty;
For k :
internalField   uniform 0.3328;
boundaryField
    inlet
        type            fixedValue;
        value           uniform 0.3328;
    outlet
        type            zeroGradient;
    fixedWalls
        type            fixedValue;
    value        0.00000001;
    frontAndBack
        type            empty;
for epsilon :
dimensions      [0 2 -3 0 0 0 0];
internalField   uniform 0.3676;
boundaryField
    inlet
        type            fixedValue;
        value           uniform 0.3676;
    outlet
        type            zeroGradient;
    fixedWalls
        type            fixedValue;
    value        0.00000001;
    frontAndBack
        type            empty;
Thank for your reply and your help
Old   February 5, 2010, 11:57
Hi Gearb0x,
I think for the nut at the wall you should use calculated, too. But that shouldn't be the problem.
How good are the residuals?
Old   February 6, 2010, 03:56
I'll try with calculated and see if that changes anything, I'll let you know.
Residuals were around 10^-5 if I remember. How can I check/plot them? I tried to run the simulation for 3000, 6000, 10000 and it doesn't seem to reach a steady state for the Low-Re model. The High Re achieve steady state.
Old   February 6, 2010, 05:05
I've tried with nut = calculated @wall
it still gives weird results, even wost because now my pressure field is totally symmetrical ... :s
Is it possible that the mesh is too/not enough fine? Could that give wrong results?
Old   February 10, 2010, 11:58
Hi Gearbox,
start a simulation with standard bc's for turbulent incompressible flow.
Inlet: U,k,epsilon field fixedValues, p zeroGradient
Outlet: U,k,epsilon zeroGradient, p fixedValue
nut everywhere calculated for low-reynolds-models
and look if everything works here fine...to be sure your mesh is okay.
best regards
Old   February 10, 2010, 19:03
Thanks for the hint!
Apparently the mesh was the problem since now I get "nice" results
In fact, the grading was wrong : it switched between "fine" and "coarse" part too abruptly.
Best regards
Old   June 15, 2018, 17:33
Reviewer #2
randolph is on a distinguished road
Hey,
Just curious which low Re k epsilon formula does this setting enable?
Thanks!
randolph is offline   Reply With Quote
help with wall functions Nick Georgiadis Main CFD Forum 10 January 17, 2017 11:03
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 21:30
Wall functions tutlhino OpenFOAM Pre-Processing 0 July 2, 2007 06:04
Multicomponent fluid Andrea CFX 2 October 11, 2004 06:12
When I use the wall functions....! maximus Main CFD Forum 7 January 20, 2003 10:35
