OpenFOAM 1.5 dev
Old   March 25, 2010, 02:45
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
See my post #78 in this thread.
Best regards,
Niels
ngj is offline   Reply With Quote
Old   April 1, 2010, 03:34
Default OpenFOAM 1.5-dev installation procedure
  #82
NAVEEN.K.M
naveen is on a distinguished road
hi EVERYBODY,
I am from India working in National Aerospace Laboratories as research fellow. I am using OpenFOAM 1.4.1, 1.5,1.6.x past 2 years solved different problems on external aerodynamics like flow over airfoils, wings, cylinders,multi-element aerofoils etc without any problems.
Now i want to work on turbomachinery problems for flow analysis, for that i want to use OpenFOAM 1.5-dev (ggi) for solving. i am facing problem for installing 1.5-dev on my
system (mandriva 2008.1) using svn repository. If i install 1.5-dev, i am getting gcc error after foamInstallationTest.I need help from your side to install 1.5 dev for my work.
Also i want to know how to activate the subversion (svn) in
OpenFOAM sourceForge.net. Please help me in this regard.
naveen is offline   Reply With Quote
Old   May 1, 2010, 13:40
David
David_010 is on a distinguished road
Hi Norman
First of all, thank you for this post. I need to install OpenFOAM-1.5-dev because I want to use the conjugateFoam solver. I have followed your suggestions in my system (OpenSuse 11.2 64 bits) but I obtain an error in the log file, after run ./Allwmake. I think I have installed all the necessary packages, but, may be I need something more, or I am doing something wrong.
It is in Spanish, but the error says that "due to the errors, the objective 'aplication' wasn't reconstructed. And the message that appears near to wmake several times says 'nothing is done for application'
May be you have an idea of the problem I have. Once again, thank you very much for your help.
David
David_010 is offline   Reply With Quote
Old   May 1, 2010, 14:12
David
Repeated post
Old   May 1, 2010, 21:37
Pavan
rieuk is on a distinguished road
Hi David, have you read all the posts in this thread? If not I suggest you do ...
rieuk is offline   Reply With Quote
Old   May 2, 2010, 06:30
David
Hi rieuk
Yes, I have read all the post and tried all the suggestions, but I can not solve my problem. I have installed all the necessary packages (I think it at least). With ./Allwmake I can compile some solvers, but not all.
Thanks for your attention
David
Old   May 2, 2010, 14:41
norman1981's Avatar
Norman Del Puppo
norman1981 is on a distinguished road
Originally Posted by David_010 View Post
Hi rieuk
David
Dear David,
did you run Allwmake twice? If not, try to run Allwmake again without cleaning.
Regards,
Norman
norman1981 is offline   Reply With Quote
Old   May 2, 2010, 15:01
David
Hi Norman!
Thanks for your reply. Yes, I have tried it, but I obtain the same result. I can run some solvers, like icoFoam, but I cannot run conjugateHeatFoam. The only package I have not managed to install is bisonc++ (I have installed bison), but I don't know how to install it. Could it be the reason?. I'm trying to install the 1.5-dev without have the 1.6 version, by tipping directly:
. $HOME/OpenFOAM/OpenFOAM-1.5-dev/etc/bashrc
source ~/.bashrc
and then ./Allwmake.
Thanks a lot for your help
David
Old   May 2, 2010, 19:19
andy
andy_ is on a distinguished road
As Norman suggested, can you run make again and give us the first error it reports.
We stopped using Suse when it went problematic a few years ago. There is no bison++ in the current distribution and 1.5-dev compiles without errors. If bison++ has disappeared from Suse it may be because bison now includes whatever was in bison++ but this is a guess on my part. The errors being generated should tell you what is missing.
Did you install 1.5-dev from the subversion repository? This is a later version with a bunch of bug fixes/additions and is usually preferable to the original version.
andy_ is offline   Reply With Quote
Old   May 3, 2010, 15:56
David
Dear Andy and Norman
This is the output of re-run ./Allwmake. Sorry about the language, but the messages in Spanish basically say that :" Nothing to be done for application", and "due to errors, the object application was not re-built".
I have download 1.5-dev from "https://openfoam-extend.svn.sourceforge.net/svnroot/openfoam-extend/trunk/Core/OpenFOAM-1.5-dev/", as Norman suggested.
David
Old   May 3, 2010, 18:24
andy
David
" Nothing to be done for application" This is not a problem. It means the executable or library has already been created.
"due to errors, the object application was not re-built". This is a summary message and is not particularly useful in itself. What is useful is the error that precedes it.
I think the first problem might be "está actualizado" if this means out of date. Is the time on your computer correct? (type "date"). If it is not then you should fix it, delete everything and start again. Make gets confused if the clock is wrong because it uses the age of the files to determine what needs to be built and what does not.
Old   May 4, 2010, 12:20
David
Dear Andy
I tested the "date" and it was ok:
mar may  4 15:20:05 UTC 2010
So, I'm a bit lost. In the setting.sh file, the compiler is set to system. Is it ok? or I have try to compile from OpenFOAM? because my gcc version is 4.4.1. Well, my knowledge about linux is limited.
Thanks again
David
Old   May 5, 2010, 01:38
Default OpenFOAM 1.5 dev
  #93
NAVEEN.K.M
Dear David,
Download 1.5-dev from the svn repository by typing the below code in the terminal in the OpenFOAM directory:
svn co http://openfoam-extend.svn.sourcefor...-extend/trunk/
Old   May 5, 2010, 14:20
David
Dear Naveen
Thanks for your help. Yes, that is the version I have been trying to install. So, I think the problem is not with it. But any suggestion is welcome.
Thanks again
David.
Old   May 5, 2010, 14:49
bigphil's Avatar
Philip Cardiff
bigphil will become famous soon enoughbigphil will become famous soon enough
Hi David,
I don't want to give conflicting advice, but I use OpenFOAM-1.5-dev from http://powerlab.fsb.hr/ped/kturbo/openfoam/release/, and I use this on my OpenSUSE 11.0 and it works (and compiles) fine (for me).
If you have run out of ideas, you could try this version.
But before you do that,
out of curiosity, what happens when you go to the conjugateHeatFoam directory (cd $FOAM_SOLVERS/conjugate/conjugateHeatFoam)
and then execute
"wclean"
and
then
"wmake",
what error does it give?
Philip
bigphil is offline   Reply With Quote
Old   May 5, 2010, 15:09
David
Hi Philip
Well, I've done it now, and when I execute "wclean" and "wmake" in the conjugateHeatFoam solver, I don't get any error. But when I go to the conjugateHeatFoam tutorial (conjugateCavity) in:
cd OpenFOAM/OpenFOAM-1.5-dev/tutorials/conjugateHeatFoam/conjugateCavity
and do ./Allrun
the log file says:
/home/David/OpenFOAM/OpenFOAM-1.5-dev/bin/tools/RunFunctions: line 40: conjugateCavity: order was not found.
Thank you very much for your help
David
Old   May 5, 2010, 15:55
bigphil's Avatar
Philip Cardiff
David,
hmmnn I have never used conjugateHeatFoam before, but when I tried it there now, I a similar error ("command not found" instead of "order not found") but I pressume this is just due to the translation.
As far as I can see the conjugateHeatFoam solver compiled fine, does this tutorial case actually work? Has anyone used this tutorial in this version of OpenFOAM? Maybe it was created in a previous OpenFOAM version and doesn't actually work at the moment in this version of OpenFOAM.
Allrun is just a script, and it calls another script called RunFunctions which tries to execute conjugateCavity at line 40 in RunFunctions.
Allrun passes the name of an application to RunFunctions, which in this case is "conjugateCavity", but since "conjugateCavity" isn't a application then RunFunctions says "command not found".
If you change the 4th line in Allrun (which currently is " application='basename $currDir' ") to " application='conjugateHeatFoam' ".
Then the Allrun script starts at least but then it gets some error with the case (Attempt to cast type wall to type lduInterface....) which I don't understand.
So, either my OpenFOAM is not set-up correctly, and I get the same errors as you, or maybe this tutorial is old and faulty...
I am not really sure, maybe somebody else has an idea.
Sorry I couldn't help,
Philip
Old   May 5, 2010, 16:35
David
Hi Philip
Thank you very much for your attention. You have really helped me in the way that now I know that it isn’t a compilation error of my computer. I will continue looking for a solution, but in a different way.
Thank you again
David
Old   May 5, 2010, 18:01
norman1981's Avatar
Norman Del Puppo
Hi Philip
Thank you again
David
I compiled the current svn OpenFOAM-1.5-dev revision without errors in my OpenSUSE 11 that comes with the gcc 4.3 compiler. I saw an error in your last log file that seems to me related to your compilation environment but I might be wrong...
Anyway regarding the conjugateCavity there's a mistake in the allRun script and the runFunction runs the case folder instead of the solver.. run the conjugateHeatFoam inside the conjugateCavity..in this way it worked for me!
Regards
Norman
[OpenFOAM] Paraview/Parafoam in OpenFoam 1.5 dev titio ParaView 0 December 9, 2009 13:13
[OpenFOAM] Paraview/Parafoam in OpenFoam 1.5 dev titio ParaView 0 December 9, 2009 13:12
OpenFOAM 1.5 installation on OpenSUSE 11.0 bigphil OpenFOAM Installation 16 April 29, 2009 07:28
Problem installing OpenFOAM 1.5 installation on RHEL 4. vwsj84 OpenFOAM Installation 4 April 23, 2009 05:48
OpenFOAM Version 1.5 Released OpenFOAM discussion board administrator OpenFOAM Announcements from ESI-OpenCFD 0 July 14, 2008 19:22
