OpenFOAM 1.5 dev
Old   February 5, 2010, 06:23
LVDH's Avatar
Andre Z
LVDH is on a distinguished road
Well and I have installed OF 1.6. I do have a 64bit system.
I am going to do what norman suggested. When its done I will post the log.
LVDH is offline   Reply With Quote
Old   February 5, 2010, 06:30
norman1981's Avatar
Norman Del Puppo
norman1981 is on a distinguished road
If you have a 64-bit system you have to replace this line:
wget http://mesh.dl.sourceforge.net/sourc....linuxGcc.gtgz
with this one:
wget http://mesh.dl.sourceforge.net/sourc...inux64Gcc.gtgz
and the line
tar xzf ThirdParty.linuxGcc.gtgz
with this one:
tar xzf ThirdParty.linux64Gcc.gtgz
because you have to choose the binaries in accord with your system architecture.
Norman
norman1981 is offline   Reply With Quote
Old   February 5, 2010, 06:51
LVDH's Avatar
Andre Z
I do not know why but this command:
svn co https://openfoam-extend.svn.sourcefo...enFOAM-1.5-dev
does not work. That is why I initially downloaded the *.tar.gz.
The message that appears when I try the svn co is this:
XXXX:~/OpenFOAM> svn co https://openfoam-extend.svn.sourcefo...enFOAM-1.5-dev
svn: OPTIONS von »https://openfoam-extend.svn.sourcefo...enfoam-1.5-dev«: Could not resolve hostname `openfoam-extend.svn.sourcefo...enfoam-1.5-dev': Host not found (https://openfoam-extend.svn.sourcefo...enfoam-1.5-dev)
Is it possible that the IT at the company I am working in is blocking this action?
Old   February 5, 2010, 06:54
LVDH's Avatar
Andre Z
This is crazy, the both wgets result in files named like this:
sourc....linuxGcc.gtgz?download&failedmirror=mesh. dl.sourceforge.net
The good thing is that I have already arranged my beerdrinking for this night.
Old   February 5, 2010, 06:59
norman1981's Avatar
Norman Del Puppo
1) Copy the full path please:
'https://openfoam-extend.svn.sourceforge.net/svnroot/openfoam-extend/trunk/Core/OpenFOAM-1.5-dev'
2) Try simply copying the other two wget path (without the wget command of course) and paste them in a new tab of your browser.. it should ask you to save the package.
Old   February 5, 2010, 07:38
LVDH's Avatar
Andre Z
OK,
Norman thanks to your help the ./Allwmake is running again.
I really appreciate your help.
Thank you very much!
Old   February 5, 2010, 09:09
bigphil's Avatar
Philip Cardiff
bigphil will become famous soon enoughbigphil will become famous soon enough
The 'dev' can also be downloaded from: http://powerlab.fsb.hr/ped/kturbo/OpenFOAM/release/
Philip C
bigphil is offline   Reply With Quote
Old   February 5, 2010, 09:52
dadros is on a distinguished road
Hi Andre, Norman and others,
I think I have the same problem:
Also trying to compile OF-1.5-dev, already tried with ThirdParty package of 1.6, and OpenFOAM-1.5-dev/etc/settings.sh altered accordingly.
Now following Normans suggestion and using that ThirdParty package.
I get the following error
/home/ddros/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/bin/../libexec/gcc/x86_64-unknown-linux-gnu/4.3.1/cc1: error while loading shared libraries: libmpfr.so.1: cannot open shared object file: No such file or directory
make: *** [Make/linux64GccDPOpt/adler32.o] Error 1
make: *** Waiting for unfinished jobs....
I think I know what it is. It has to do with Norman 0) step. I am missing the mpfr library. That is why I was using the ThirdParty package of 1.6, the mpfr library is included in that one.
If I am going to install the mpfr library separately I also need the gmp library I think?
My question: how to install the correct versions of these two libraries, in the correct order/place? Just copying form the 1.6 ThirdParty package seems a bit harsh.
dadros is offline   Reply With Quote
Old   February 5, 2010, 10:24
Elvis
elvis will become famous soon enough
@ moksen take a look at svn
http://openfoam-extend.svn.sourcefor...sticFluidFoam/
elvis is offline   Reply With Quote
Old   February 5, 2010, 10:28
LVDH's Avatar
Andre Z
this is my last post for this week.
The included log shows the new failures.
You can find them by searching for "Fehler".
I have already done that but have no idea how to solve them.
Have a nice weekend,
Andre
Old   February 5, 2010, 10:45
norman1981's Avatar
Norman Del Puppo
Philip C
Dear Philip,
you are right but I think using the SVN version is better because you can upgrade your OF without too much troubles while the powerlab's version is not kept frequently updated..BTW it is only my opinion and that is also a good alternative. Thanks for the contribution,
Norman
Old   February 5, 2010, 10:53
norman1981's Avatar
Norman Del Puppo
Originally Posted by LVDH View Post
Andre
try re-running ./Allwmake without the allwclean.. I saw your decompositionMethods library was not compiled.
Norman
Old   February 8, 2010, 04:27
LVDH's Avatar
Andre Z
It is working now.
Thank you very much.
Old   February 22, 2010, 09:00
maja ondracka
maja is on a distinguished road
Hi! I'm desperate!
I spent a week trying to install OF-1.5-dev for the same reason Andre did. I need GGI working. I followed the instructions I found here from Norman. Everything was OK (finally) until I had to run Allwmake. I did not find any Allwmake script in $HOME/OpenFOAM directory, so I ran Allwmake in $HOME/OpenFOAM/OpenFOAM-1.5-dev directory. Aftre that I got errors like this:
bin/linux64GccDPOpt/fluentMeshToFoam
/usr/bin/ld: cannot find -liberty
collect2: ld returned 1 exit status
make[3]: *** [/home/maja/OpenFOAM/OpenFOAM-1.5-dev/applications/bin/linux64GccDPOpt/fluentMeshToFoam] Error 1
make[2]: *** [fluentMeshToFoam] Error 2
make[4]: Nothing to be done for `application'.
I have Ubuntu 9.1 64 bit. I also installed OF1.6, but realized GGi is not working there. I renamed the OpenFOAM directory where OF1.6 is installed. But I did not delete this version. I hope this is ok.
In ~/.bashrc file I commented the line with 1.6 version.
I have no idea what else to do.
Please, someone help me.
Regards, Maja
maja is offline   Reply With Quote
Old   February 22, 2010, 09:14
Kathrin Kissling
kathrin_kissling is on a distinguished road
Hi Maja,
seems like you are missing some library.
Try to install binutils-dev on your machine. (Should work with your OS installation helper).
Best
Kathrin
kathrin_kissling is offline   Reply With Quote
Old   February 22, 2010, 09:24
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Hi Maja
You need to install "binutils-dev" which inclulde the missing dependency.
Best regards,
Niels
ngj is offline   Reply With Quote
Old   February 22, 2010, 09:49
maja ondracka
Thank you Kathrin and Niels!
It works!!
Old   February 25, 2010, 06:13
Pavan
rieuk is on a distinguished road
Hey, I've got the binutils-dev installed but get errors like Maja. No commands work even after running allwmake, for eg blockMesh gives "command not found". I've attached a portion of the allwmake output with errors. Can any one give me a hand?
File Type: gz log.txt.tar.gz (115 Bytes, 7 views)
rieuk is offline   Reply With Quote
Old   February 25, 2010, 06:22
the log file you posted seems empty..
after the build did you source your bashrc?
# . $HOME/.bashrc
Old   February 25, 2010, 06:36
Pavan
Yes of course I did source it. The lines in the bashrc file are,
. $HOME/OpenFOAM/OpenFOAM-1.5-dev/etc/bashrc
export PATH=$PATH\:$HOME/OpenFOAM/OpenFOAM-1.5-dev/wmake
Sorry about the log file, it's attached now.
I source the bashrc by typing "source ~/.bashrc"
[OpenFOAM] Paraview/Parafoam in OpenFoam 1.5 dev titio ParaView 0 December 9, 2009 13:13
[OpenFOAM] Paraview/Parafoam in OpenFoam 1.5 dev titio ParaView 0 December 9, 2009 13:12
OpenFOAM 1.5 installation on OpenSUSE 11.0 bigphil OpenFOAM Installation 16 April 29, 2009 07:28
Problem installing OpenFOAM 1.5 installation on RHEL 4. vwsj84 OpenFOAM Installation 4 April 23, 2009 05:48
OpenFOAM Version 1.5 Released OpenFOAM discussion board administrator OpenFOAM Announcements from ESI-OpenCFD 0 July 14, 2008 19:22
