thermophysicalProperties for water (constant every thing)
Old   February 1, 2010, 10:54
Default thermophysicalProperties for water (constant every thing)
openfoam1 is on a distinguished road
Hi foamers ;
I'm using chtMultiRegionFoam to solve a conjugate heat transfer problem
the fluid region on my case is water
in the tutorial case there is a thermophysicalProperties for air and it is a compulsory dictionary
can any one know how can i use water with the simplest case (constant thermal conductivity ,constant heat capacity , constant kinematic viscosity and , constant viscosity)
thanks in advance ..
openfoam1 is offline   Reply With Quote
equilibrium constant in fluent ashishpande FLUENT 1 May 30, 2014 06:43
Chemical properties that are used in Fluent kimej FLUENT 4 August 19, 2011 12:29
Creating A Constant Pitch Helical Line In Gridgen John Hinkey Pointwise & Gridgen 2 August 5, 2007 01:01
Really big problems when creating own materials da Jop FLUENT 0 June 28, 2007 12:15
Converge but monitored parameter not constant!! kanok FLUENT 2 September 25, 2003 00:53
