February 21, 2011, 08:52 |
#81 |
Rep Power: 16 |
Hello FOAMers,
I need to use the current nuSGS values in a modified pisoFoam solver (heat transfer energy equation implemented) but OF tells me, that "nuSGS" entry is missing in the turbulenceModel.H file. Do I just have to include this: //- Return the subgrid viscosity virtual tmp<volScalarField> nuSGS() const = 0; in the turbulenceModel.H file and compile it with "wmake"? Or is there anything else that I have to do? Best regards grandgo |
August 21, 2011, 08:55 |
What should be done for Pe>2
#82 | |
As you told UD is not suitable for LES and CD is suggested. If the simulation acts on a flow which not possible to reach Pe<2 by fining grids, what is your suggestion for fvScheme? I mean how is possible to use a central differencing scheme for Pe>2? Regards, |
August 21, 2011, 15:11 |
#83 | |
Alberto Passalacqua
Rep Power: 36 |
Alberto Passalacqua GeekoCFD - A free distribution based on openSUSE 64 bit with CFD tools, including OpenFOAM. Available as in both physical and virtual formats (current status: http://albertopassalacqua.com/?p=1541) OpenQBMM - An open-source implementation of quadrature-based moment methods. To obtain more accurate answers, please specify the version of OpenFOAM you are using. |
August 22, 2011, 15:45 |
#84 | |
If no, when Peclet number is more than 2 in most of domain so hybrid scheme would be same as Upwind and it has diffuse results problem yet. |
August 22, 2011, 20:36 |
#85 |
Alberto Passalacqua
Rep Power: 36 |
Assuming you are actually doing LES, and not under-resolved LES, your grid size should satisfy the condition on Pe' in most of the domain. This is clearly very challenging for high Reynolds numbers, and the strategy to workaround this problem would be to use very high-order schemes. In general, in the literature it is clearly shown that upwind schemes, even of high-order, are very dissipative and not suitable for LES. In practical applications, you are often not interested in the resolving all the details exactly, so some error might be acceptable (as long as you know you have it).
The 4th-order scheme has to satisfy a similar stability condition to the second-order one, so you are at square one :-) There are a variety of "filtered" schemes, like SFCD and others which are considered "better" for LES by some user. I do not have direct experience: all the LES I did was with central schemes, because I wanted the best possible accuracy with the code in use. Best,
August 4, 2013, 09:26 |
#86 |
sqing
Rep Power: 14 |
Hi foamers I find that there is no dynSmagorinsky model in my OF version(OF 2.1.1), but there is a homogeneousDynSmagorinsky model. So is the latter one a similar model with the dynSmagorinsky model? If it's not, in which OF version can I find the dynSmagorinsky model? I have calculated the case about the interaction of plane wall jets with external stream with the standard Smagorinsky + VanDrist damping function, however the result turned out no so good as I expected. Especially, the velocity is much lower than the exp in the near wall region. Is it suitable to use the dynSmagorinsky model or homogeneousDynSmagorinsky model to simulate this case? Best regards
August 4, 2013, 09:57 |
#87 | |
Roro Wang
Rep Power: 16 |
Maybe you can try this link: http://albertopassalacqua.com/?page_id=1145 foamWang Quote:
August 4, 2013, 22:13 |
#88 | |
sqing
Rep Power: 14 |
August 15, 2013, 03:58 |
#89 |
sqing
Rep Power: 14 |
Hi Heng Xiao
I have used the dynamic model that alberto offered in a plane wall jet case. However it didn't give a good result as I expected. I have compared the result with the exp data and RANS result. It turns out the velocity near wall is much lower than the exp data. It has a opposite result with yours. I have simulate it with good mesh and the yplus is about 0.2 at first grid. I don't know what factors may lead to this result, can anyone help me? Thanks! Regard Sunxing |
March 2, 2014, 08:47 |
#90 |
Florian Ries
Rep Power: 12 |
I compare the dynamic model in OpenFOAM (homoDynSmag OF 2.2.2) with the dynamic model (described in Pope respectively in C.Fureby "A comparative study of subgrid scale models in homogeneous isotropic turbulenc") and I have the some Problems in understanding. In Pope (F(.) means filtered): [1] nu_SGS = cS * delta^2 * sqrt(2 * S_ij S_ij) [2] cs = (M_ij L_ij)/(M_kl M_kl) where [3] S_ij = 0.5 (ui,j + uj,i) [4] M_ij = 2 * delta^2 * (F(sqrt(2 * S_ij S_ij) S_ij) - F(sqrt(2 * S_ij S_ij)) F(S_ij)) [5] L_ij = F(ui uj) - F(ui) F(uj) In Fureby: similar to Pope but different filtering. It should be model A2 "Dynamic coefficient algebraic eddy-viscosity model (AVM)" In OF 2.2.2 (homogeneousDySmagorinsky, <.> means averaged): [6] nu_SGS = cD * delta^2 * sqrt(S_ij S_ij) [7] cD = 0.5 (<L_ij M_ij>)/(<M_kl M_kl>) [8] S_ij = D_ij = S_ij Pope [9] M_ij = delta^2 * (F(sqrt(S_kl S_kl) Sij) - 4 * sqrt(<S_kl> <S_kl>) <S_ij>) [10] L_ij = F(ui uj) - F(ui) F(uj) I marked the differences of these models. - First difference is the factor 0.5 in Eq[7] in comparison to Eq[2]. This comes from the factor 2 in Eq[4]. If we put this in Eq[2] we get 0.5 (ok) - Second difference is the different filtering in M_ij. What effect does this have???? (x) - Third difference is the factor 4 in Eq[9] in comparison to Eq[4]. (x) - Fourth difference is the factor 2 in mag(S_ij). (x) In my opinion these models are different or I`m not able to bring the OF-model in the form of pope/Fureby-model. The Problem lies in the formulation of M_ij. If it is possible, anyone can please give some advice? kind regards Florian |
March 15, 2014, 23:07 |
#91 | |
Peter
Rep Power: 15 |
March 17, 2014, 02:42 |
#92 |
Florian Ries
Rep Power: 12 |
Hi Sunxing and palmerlee,
pherhaps the velcoity is too small, because even in the dynamic model Cs isn't 0 at the wall. As e result of this, nusgs isn't 0 -> velocity is smaller. If you use a real dynamic model check Cs at the wall. If it is far away from 0 -> velocity to small. Pherhaps you should use the WALE model. see here: http://aerojet.engr.ucdavis.edu/flue...ug/node508.htm the model isn't imoplemented in OF (as far as I know). kind regards Florian |
March 17, 2014, 02:52 |
#93 |
Florian Ries
Rep Power: 12 |
Hi Foamers,
now I have understood the implementation of homoDynSma-model in OF. For people that are interested in it: nuSGS = cD*Delta^2*(Sij Sij)^0.5 cD = <Lij Mij>/<Mkl Mkl> <.>: means averaging over the whole domain Lij = filter(ui uj) - filter(ui) filter(uj) Mij = Delta^2 * (filter((Skl Skl)^0.5 Sij) - 4*(filter(Skl) filter(Skl))^0.5 filter(Sij)) with the testfilter twice the gridfilter Delta_T = 2 * Delta Mij = Delta^2 * filter((Skl Skl)^0.5 Sij) - Delta_T^2 * (filter(Skl) filter(Skl))^0.5 filter(Sij) then it is the same model as in Pope (but oter filtering) kind regards Florian |
March 17, 2014, 21:49 |
#94 | |
Peter
Rep Power: 15 |
Thank you for your reply! How about van Driest damping, then? Could it solve this problem. kind regards Peter |
March 18, 2014, 03:41 |
#95 |
Florian Ries
Rep Power: 12 |
Hi Palmerlee,
van Driest damping is not a good choice for dynamic models. For static Smagorinsky you can use it. In my opinion there are two easy possibilities. WALE-Model or Vreman Model. These two models are very "easy" to implement. Do you have incompressible flow?? Attached you can find the WALE model I implemented in OpenFoam. It is a first version, so pherhaps there are some mistakes in it. If you will use it, please let me know about the results. For version OF2.... you can put the files in a folder in your run folder and type wmake libso. For the simulation you have to change: 1) at the begining of the controlDict include this: libs ( "libOpenFOAM.so" "libincompressibleTurbulenceModel.so" "libincompressibleLESModels.so" "libWALELESModel.so" ); application pimpleFoam; 2) In LES Properties use this: FoamFile { version 2.0; format ascii; class dictionary; location "constant"; object LESProperties; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // LESModel WALE; turbulence on; printCoeffs on; delta cubeRootVol; cubeRootVolCoeffs { deltaCoeff 1; } WALECoeffs { cw 0.325; } That should work and solve your problem. kind regards Florian |
March 18, 2014, 03:44 |
#96 |
Florian Ries
Rep Power: 12 |
ok .tar is a invalid file in this forum?????
here a zipped tar: I hope this will work |
March 18, 2014, 03:47 |
#97 |
Florian Ries
Rep Power: 12 |
the description in the headerfile is from Smagorinsky-Model. But the imoplemented model is WALE. kind regards Florian |
March 18, 2014, 08:29 |
#98 | |
Peter
Rep Power: 15 |
Thank you very much for the code and the description! I will dig deep in this WALE model. Yes, my case have incompressible flow. It is a jet impingement flow, which has three different flow regimes: the free jet region, the stagnation region and the wall jet region. Most LES simulations for this type of flow use the dynamic Smagorinsky model in literature. You said that van Driest damping is not a good choice for dynamic models, can you explain it to me a little, perhaps? Best regards Peter |
March 18, 2014, 10:12 |
#99 |
Florian Ries
Rep Power: 12 |
Hi Peter,
usually van Driest is used to model the behaviour of nuSgs ~ ył near the wall. The dynamic procedure of Germano do the same by changing the Smagorinsky-parameter. So I would not use van Driest for dynamic models, because both do the same. The advantage of the dynamic model is, that you don't have to "guess" the Smagorinsky-constant. The model will do that for you. Important is, what model do you use?? Is it the homogeneousDynSmagorinsky-Model in OF?? If yes, the constant is averaged over the whole domain. That would be bad near the wall. If you use a dynamicSmagorinsky model, how do you smooth the Smagorinsky-parameter. A local smoothing can be wrong near the wall (in my opinion). Pherhaps it is better to underrelax the Smagorinsky-parameter over time and than do the clipping. Or, if it is stable, do not smooth the Smagorinsky-parameter. You can also do LES with wall functions log-law, Werner-Wengle-model and so on. This should be better than damping. I'm not so familar with impinging jets. I will check this topic and let you know. kind regards Florian |
March 19, 2014, 02:44 |
#100 | ||
Peter
Rep Power: 15 |
Thanks a lot for the reply! I use the dynamicSmagorinsky model from here: https://bitbucket.org/albertop/dynamicsmagorinsky The Description is: Quote:
help for different between les model (subgrid-scale model) | liuyuxuan | FLUENT | 1 | October 2, 2009 16:25 |
LES and combustion model | Margherita Cadorin | CFX | 0 | October 29, 2008 06:24 |
regarding eddy break up model | dj | CFX | 0 | September 30, 2003 03:05 |
Why Turbulence models are not universal. | Senthil | Main CFD Forum | 4 | July 5, 2000 05:34 |
Advanced Turbulence Modeling in Fluent, Realizable k-epsilon Model | Jonas Larsson | FLUENT | 5 | March 13, 2000 04:27 |
