Region Status issues in paraFoam
Old   January 28, 2010, 17:54
Default Region Status issues in paraFoam
stefan
oldschool is on a distinguished road
have just installed OpenFoam without any troubles and tryed out the first tutorial (cavity).
Unfortunately, something doesn't seem to be right with my paraFoam. The Region Status pannel is not where its supposed to be (doesn't exist).
However, it is very important for me to check the boxes in the region status pannel, as I won't e able to see my mesh, shape and so forth.
I have read the tutuorial numerous times and I just can't find what I might have done wrong.
I did following steps:
1) I added the bashrc comand in order to run open foam in my terminal
2)cd $FOAM_RUN/tutorials/incompressible/icoFoam/cavity
3) I have done checkMesh
4) paraFoam (files which are being created through icoFoam area already there for the cavity example. But have also tryed to delete it and run the calculation from the beginnning)
It opens up my paraFoam Window, where I can also see the cavity part being which has been loaded.
Got the same issue with all other examples which are supplied with openfoam
Thank you already for your replies and help
oldschool is offline   Reply With Quote
Old   January 29, 2010, 10:10
Aniko Rakai
ancsa is on a distinguished road
I also didn't find Region Status at the beginning but the Mesh Part on the left hand side of paraFoam under properties panel seems to be just the same in my case.
ancsa is offline   Reply With Quote
Old   January 29, 2010, 12:29
stefan
Hello ansca, I have tryed using MeshPart, but for the case of the cavity, it won't show a provile or a mesh after clicking apply. Same thing happens with most of the other examples from the tutorial. In some case I might be able to see the simple mesh, though.
Anyone an idea what might be the issue.
Thanks in advance
[Commercial meshers] Using starToFoam clo OpenFOAM Meshing & Mesh Conversion 33 September 26, 2012 05:04
[OpenFOAM] Region Status Issues oldschool ParaView 3 May 17, 2010 09:08
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 21:30
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 05:15
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 09:19
