Meshing an axissymetric 2D case - Problems
Old   January 27, 2010, 14:31
Default Meshing an axissymetric 2D case - Problems
Andreas Jörg
Andyjoe is on a distinguished road
This day and the half of last night I spend trying to mesh an axissymetrc 2D case.
First I made a box, which was the "windtunnel". Two sites were wedges, I did it like in the OpenFOAM documentation. Then I inserted a box, which lines were polylines. Here the first problem occured. The interpolationpoints inserted had an x and y coordinate smaller than 4, but some of the mesh points had coordinates with values above 300. The convertToMeters was set to 1. So the mesh doesn't look good when I loaded it in Paraview.
I tryed simpleSpline etc. too, but then blockMesh crashed.
Then I decided to use only arcs and boxes. The mesh looked good then, but it has too much cells in z-direction. For both boxes I set the cell number in z direction to 1, but this advice seems to be ignored.
My next test was to make only one channel. The y coordinate of the ground of this tunnel follows the geometry of the simulated body. Then blockMesh always crashes, without given an error, it just tells the lines, in which the libs are crashed.
So my question is, how it is possible to create an axissymetric 2D case. It would be easy for me, if there is a possibility to use polyLines etc, because I can calculate the test objects with functions, which enables me to get Points. Furthermore I would be interested in how stable blockMesh is or if anyone knows Bugs in it.
Thank you in advertise for any answer
Andyjoe is offline   Reply With Quote
Old   January 27, 2010, 16:11
Andreas Jörg
The last hours I kept on trying. Now I've got a concrete error message. First of all, here my blockMeshDict:
 FoamFile
     version     2.0;
     format      ascii;
     class       dictionary;
     object      blockMeshDict;
convertToMeters 1;
vertices
(0 0 0)
(0.6 0.125 0)
(0.6  0.125 0.0108)
(0  0 0)
(0 1 0)
(0.6 1 0)
(0.6 1 0.087)
(0 1 0.087)
(0.6 0.125 0)
(0.91 0.125 0)
(0.91 0.125 0.0108)
(0.6 0.125 0.0108)
(0.6 1 0)
(0.91 1 0)
(0.91 1 0.087)
(0.6 1 0.087)
(0.91 0.125 0)
(1.91 0.45 0)
(1.91 0.45 0.039)
(0.91 0.125 0.0108)
(0.91 1 0)
(1.91 1 0)
(1.91 1 0.087)
(0.91 1 0.087)
(1.91 0.45 0)
(2.37 0 0)
(2.37  0 0)
(1.91  0.45 0.0108)
(1.91 1 0)
(2.37 1 0)
(2.37 1 0.087)
(1.91 1 0.087)
blocks
hex (0 1 2 0 4 5 6 7) (200 200 1) simpleGrading (1 1 1) //windtunnel
hex (1 9 10 3 6 13 14 7) (100 100 1) simpleGrading (1 1 1) // tail block
hex (9 17 18 10 13 21 22 14) (200 150 1) simpleGrading (1 1 1) // tail block
hex (17 26 26 18 21 29 30 22 ) (250 150 1) simpleGrading (1 1 1) // tail block
edges
arc 1 2 (0.2 0.098 0)
arc 3 4 (0.2 0.098 0.008526)
arc 17 26 (2.23 0.387 0)
arc 18 26 (2.23 0.387 0.0067338)
patches
patch inlet
(0 4 7 0)
patch outlet
(26 30 29 26)
patch top
(5 6 7 4)
(5 13 14 6)
(14 22 21 13)
(22 29 30 21)
patch phoenix
(0 2 1 0)
(1 2 10 9)
(10 18 17 9)
(18 26 25 17)
 wedge frontback
(0 1 5 4)
(0 7 6 2)
(2 6 22 18)
(1 9 13 5)
(9 17 21 13)
(10 14 21 17)
(16 25 29 20)
(17 21 30 26)
mergePatchpairs
Not every point defined is used. The reason is, that it makes counting easier for me. For example I know, that the secound box has the vertices 16-23.
The important line of the error message is:
face 1 in patch 1 does not have neighbour cell face: 4(5 13 14 6)#0
Googling this errormessage gave one result. There the error was in mergePatchpairs. I've already got this message too, I solved the problem by inverting the order of the vertices in the brackets. So I guess this errormessage can have several reasons. But I don't know where to look anymore. I think the vertices are in the correct order, and changing the order doesn't change anything at the message.
Could anyone assume, where the mistake could be, or has anyone experience with this errormassage?
Old   January 27, 2010, 22:56
Jinbiao Xiong
JinBiao is on a distinguished road
Send a message via MSN to JinBiao
Hi, Andreas
I am also trying to do a 2D axis-symmetrical mesh. The last error you have may be caused by a wrong ordering of the vertices when you define the hexes or patches. Actually I had exact same error. And I eliminated it by re-order the vertices.
Here I have another problem. I always got an failure when I do checkMesh.
***Number of edges not aligned with or perpendicular to non-empty directions: 11438
<<Writing 11739 points on non-aligned edges to set nonAlignedEdges
This failure even occur when I run the example provided in the openfoamwiki for 2D axis-symmetric case. Does anyone have an idea why this happens?
Regards
Jinbiao
JinBiao is offline   Reply With Quote
Old   January 28, 2010, 09:29
Andreas Jörg
Hi Jinbiao,
have you tried to look at your mesh with paraView? This often helps to spot the point, where the mesh is bad, whereas checkMesh just tells you numbers.
Old   January 28, 2010, 16:44
Andreas Jörg
I kept on trying. Now paraview shows a mesh which seems to be ok. Theoretically this can be applied to any 2D Body which can be described as a function. Scince the body is symmetric, I only simulate the upper half. But with the polylines not use, the surface at the bottom can be also described.
 FoamFile
     version     2.0;
     format      ascii;
     class       dictionary;
convertToMeters 1;
vertices
(2.37 0 0.000000)
(1.92 0.45 0.000000)
(0 0 0)
(0.6 0.125 0.000000)
(0.1 0 0.000000)
(2.37 0 0.100000)
(1.92 0.45 0.100000)
(0.1 0 0)
(0.6 0.125 0.100000)
(0.1 0 0.1)
( 2.500000  1.000000 0)
(-0.000000  1.000000 0)
(-0.000000 -0.000000 0)
( 2.500000 -0.000000 0)
( 2.500000  1.000000 .1)
(-0.000000  1.000000 .1)
(-0.000000 -0.000000 .1)
( 2.500000 -0.000000 .1)
blocks
hex (1 0 10 11 6 5 14 15) (100 100 1) simpleGrading (1 1000 1) //rear
hex (0 4 13 10 5 9 17 14) (100 100 1) simpleGrading (1 1000 1) // middle
hex (4 3 12 13 9 8 16 17) (100 100 1) simpleGrading (1 1000 1) // else
hex (3 1 11 12 8 6 15 16) (100 100 1) simpleGrading (1 1000 1) // front
edges
line 10 11
line 14 15
line 11 12
line 15 16
line 12 13
line 16 17
line 13 10
line 17 14
line 10 11
line 14 15
line 11 12
line 15 16
line 12 13
line 16 17
line 13 10
line 17 14
polyLine 0 1 (
(    2.33    0.18547    0    )
(    2.21    0.34409    0    )
(    2.15    0.38678    0    )
(    2.08    0.42059    0    )
(    2.06    0.42767    0    )
(    2.04    0.4337    0    )
(    2.02    0.43875    0    )
(    2    0.44283    0    )
(    1.98    0.44598    0    )
(    1.96    0.44822    0    )
(    1.94    0.44956    0    )
/*(1.92    0.45    0)
(1.93    0.44989    0)
(1.94    0.44956    0)
(1.95    449    0)
(1.96    0.44822    0)
(1.97    0.44721    0)
(1.98    0.44598    0)
(1.99    0.44452    0)
(2    0.44283    0)
(2.01    0.44091    0)
(2.02    0.43875    0)
(2.03    0.43635    0)
(2.04    0.4337    0)
(2.05    0.43081    0)
(2.06    0.42767    0)
(2.07    0.42426    0)
(2.08    0.42059    0)
(2.09    0.41665    0)
(2.1    0.41243    0)
(2.11    0.40792    0)
(2.12    0.40311    0)
(2.13    0.39799    0)
(2.14    0.39256    0)
(2.15    0.38678    0)
(2.16    0.38066    0)
(2.17    0.37417    0)
(2.18    0.36729    0)
(2.19    0.36    0)
(2.2    0.35228    0)
(2.21    0.34409    0)
(2.22    0.33541    0)
(2.23    0.32619    0)
(2.24    0.31639    0)
(2.25    0.30594    0)
(2.26    0.29479    0)
(2.27    0.28284    0)
(2.28    0.27    0)
(2.29    0.25612    0)
(2.3    0.24104    0)
(2.31    0.2245    0)
(2.32    0.20616    0)
(2.33    0.18547    0)
(2.34    0.16155    0)
(2.35    0.13266    0)
(2.36    0.09434    0)
(2.37    0    0)*/
polyLine 5 6 (
(    2.33    0.18547    0.1    )
(    2.21    0.34409    0.1    )
(    2.15    0.38678    0.1    )
(    2.08    0.42059    0.1    )
(    2.06    0.42767    0.1    )
(    2.04    0.4337    0.1    )
(    2.02    0.43875    0.1    )
(    2    0.44283    0.1    )
(    1.98    0.44598    0.1    )
(    1.96    0.44822    0.1    )
(    1.94    0.44956    0.1    )
/*(1.92    0.45    0.1)
(1.93    0.44989    0.1)
(1.94    0.44956    0.1)
(1.95    449    0.1)
/*(1.96    0.44822    0.1)
(1.97    0.44721    0.1)
(1.98    0.44598    0.1)
(1.99    0.44452    0.1)
(2    0.44283    0.1)
(2.01    0.44091    0.1)
(2.02    0.43875    0.1)
(2.03    0.43635    0.1)
(2.04    0.4337    0.1)
(2.05    0.43081    0.1)
(2.06    0.42767    0.1)
(2.07    0.42426    0.1)
(2.08    0.42059    0.1)
(2.09    0.41665    0.1)
(2.1    0.41243    0.1)
(2.11    0.40792    0.1)
(2.12    0.40311    0.1)
(2.13    0.39799    0.1)
(2.14    0.39256    0.1)
(2.15    0.38678    0.1)
(2.16    0.38066    0.1)
(2.17    0.37417    0.1)
(2.18    0.36729    0.1)
(2.19    0.36    0.1)
(2.2    0.35228    0.1)
(2.21    0.34409    0.1)
(2.22    0.33541    0.1)
(2.23    0.32619    0.1)
(2.24    0.31639    0.1)
(2.25    0.30594    0.1)
(2.26    0.29479    0.1)
(2.27    0.28284    0.1)
(2.28    0.27    0.1)
(2.29    0.25612    0.1)
(2.3    0.24104    0.1)
(2.31    0.2245    0.1)
(2.32    0.20616    0.1)
(2.33    0.18547    0.1)
(2.34    0.16155    0.1)
(2.35    0.13266    0.1)
(2.36    0.09434    0.1)
(2.37    0    0.1)*/
/*polyLine 1 3 (
(    1.87    0.43375    0    )
(    1.53    0.32325    0    )
(    1.46    0.3005    0    )
(    1.41    0.28425    0    )
(    1.02    0.1575    0    )
(    0.96    138    0    )
(    0.92    125    0    )
(    0.73    125    0    )
(    0.7    125    0    )
polyLine 6 8 (
(    1.87    0.43375    0.1    )
(    1.53    0.32325    0.1    )
(    1.46    0.3005    0.1    )
(    1.41    0.28425    0.1    )
(    1.02    0.1575    0.1    )
(    0.96    138    0.1    )
(    0.92    125    0.1    )
(    0.73    125    0.1    )
(    0.7    125    0.1    )
/*polyLine 3 4 (
(nan 0.000000 0.000000)
polyLine 8 9 (
(nan 0.000000 0.100000)
patches (
wall phoenix
(0 1 6 5)
(1 3 8 6)
(3 4 9 8)
(4 0 5 9)
patch inlet
(11 12 16 15)
patch outlet
(13 10 14 17)
patch top
(10 11 15 14)
patch bottom
(12 13 17 16)
empty frontback
(1 0 10 11)
(3 1 11 12)
(4 3 12 13)
(0 4 13 10)
(6 5 14 15)
(8 6 15 16)
(9 8 16 17)
(5 9 17 14)
mergePatchpairs ();
Then the phoenix looks like in the first pictuere phoenix2Da, without the frontback surfaces. Every patch is where it should be. But when I apply the temporary phoenix.OpenFoam, an additional surface appears. I dont know where this surface comes from. Maybe a bug in paraFoam, because when I'm using foamToVTK and load every patch patch after patch, I got what I want to.
But with simple increasing the number of points, I got the strange result described above, with very long lines up to coordinates above 100 (picture phoenix2Dc). Is this a bug? Here the changed lines oft my blockMeshDict
polyLine 0 1 (
(    2.36    0.09434    0    )
(    2.35    0.13266    0    )
(    2.34    0.16155    0    )
(    2.33    0.18547    0    )
(    2.32    0.20616    0    )
(    2.31    0.2245    0    )
(    2.3    0.24104    0    )
(    2.29    0.25612    0    )
(    2.28    0.27    0    )
(    2.27    0.28284    0    )
(    2.26    0.29479    0    )
(    2.25    0.30594    0    )
(    2.24    0.31639    0    )
(    2.23    0.32619    0    )
(    2.22    0.33541    0    )
(    2.21    0.34409    0    )
(    2.2    0.35228    0    )
(    2.19    0.36    0    )
(    2.18    0.36729    0    )
(    2.17    0.37417    0    )
(    2.16    0.38066    0    )
(    2.15    0.38678    0    )
(    2.14    0.39256    0    )
(    2.13    0.39799    0    )
(    2.12    0.40311    0    )
(    2.11    0.40792    0    )
(    2.1    0.41243    0    )
(    2.09    0.41665    0    )
(    2.08    0.42059    0    )
(    2.07    0.42426    0    )
(    2.06    0.42767    0    )
(    2.05    0.43081    0    )
(    2.04    0.4337    0    )
(    2.03    0.43635    0    )
(    2.02    0.43875    0    )
(    2.01    0.44091    0    )
(    2    0.44283    0    )
(    1.99    0.44452    0    )
(    1.98    0.44598    0    )
(    1.97    0.44721    0    )
(    1.96    0.44822    0    )
(    1.95    449    0    )
(    1.94    0.44956    0    )
(    1.93    0.44989    0    )
(    2.36    0.09434    0    )
(    2.35    0.13266    0    )
(    2.34    0.16155    0    )
(    2.33    0.18547    0    )
(    2.32    0.20616    0    )
(    2.31    0.2245    0    )
(    2.3    0.24104    0    )
(    2.29    0.25612    0    )
(    2.28    0.27    0    )
(    2.27    0.28284    0    )
(    2.26    0.29479    0    )
(    2.25    0.30594    0    )
(    2.24    0.31639    0    )
(    2.23    0.32619    0    )
(    2.22    0.33541    0    )
(    2.21    0.34409    0    )
(    2.2    0.35228    0    )
(    2.19    0.36    0    )
(    2.18    0.36729    0    )
(    2.17    0.37417    0    )
(    2.16    0.38066    0    )
(    2.15    0.38678    0    )
(    2.14    0.39256    0    )
(    2.13    0.39799    0    )
(    2.12    0.40311    0    )
(    2.11    0.40792    0    )
(    2.1    0.41243    0    )
(    2.09    0.41665    0    )
(    2.08    0.42059    0    )
(    2.07    0.42426    0    )
(    2.06    0.42767    0    )
(    2.05    0.43081    0    )
(    2.04    0.4337    0    )
(    2.03    0.43635    0    )
(    2.02    0.43875    0    )
(    2.01    0.44091    0    )
(    2    0.44283    0    )
(    1.99    0.44452    0    )
(    1.98    0.44598    0    )
(    1.97    0.44721    0    )
(    1.96    0.44822    0    )
(    1.95    449    0    )
(    1.94    0.44956    0    )
(    1.93    0.44989    0    )
/*(1.92    0.45    0)
(1.93    0.44989    0)
(1.94    0.44956    0)
(1.95    449    0)
(1.96    0.44822    0)
(1.97    0.44721    0)
(1.98    0.44598    0)
(1.99    0.44452    0)
(2    0.44283    0)
(2.01    0.44091    0)
(2.02    0.43875    0)
(2.03    0.43635    0)
(2.04    0.4337    0)
(2.05    0.43081    0)
(2.06    0.42767    0)
(2.07    0.42426    0)
(2.08    0.42059    0)
(2.09    0.41665    0)
(2.1    0.41243    0)
(2.11    0.40792    0)
(2.12    0.40311    0)
(2.13    0.39799    0)
(2.14    0.39256    0)
(2.15    0.38678    0)
(2.16    0.38066    0)
(2.17    0.37417    0)
(2.18    0.36729    0)
(2.19    0.36    0)
(2.2    0.35228    0)
(2.21    0.34409    0)
(2.22    0.33541    0)
(2.23    0.32619    0)
(2.24    0.31639    0)
(2.25    0.30594    0)
(2.26    0.29479    0)
(2.27    0.28284    0)
(2.28    0.27    0)
(2.29    0.25612    0)
(2.3    0.24104    0)
(2.31    0.2245    0)
(2.32    0.20616    0)
(2.33    0.18547    0)
(2.34    0.16155    0)
(2.35    0.13266    0)
(2.36    0.09434    0)
(2.37    0    0)*/
polyLine 5 6 (
(    2.37    0    0.1    )
(    2.36    0.09434    0.1    )
(    2.35    0.13266    0.1    )
(    2.34    0.16155    0.1    )
(    2.32    0.20616    0.1    )
(    2.31    0.2245    0.1    )
(    2.3    0.24104    0.1    )
(    2.29    0.25612    0.1    )
(    2.28    0.27    0.1    )
(    2.27    0.28284    0.1    )
(    2.26    0.29479    0.1    )
(    2.25    0.30594    0.1    )
(    2.24    0.31639    0.1    )
(    2.23    0.32619    0.1    )
(    2.22    0.33541    0.1    )
(    2.2    0.35228    0.1    )
(    2.19    0.36    0.1    )
(    2.18    0.36729    0.1    )
(    2.17    0.37417    0.1    )
(    2.16    0.38066    0.1    )
(    2.14    0.39256    0.1    )
(    2.13    0.39799    0.1    )
(    2.12    0.40311    0.1    )
(    2.11    0.40792    0.1    )
(    2.1    0.41243    0.1    )
(    2.09    0.41665    0.1    )
(    2.07    0.42426    0.1    )
(    2.05    0.43081    0.1    )
(    2.04    0.4337    0.1    )
(    2.03    0.43635    0.1    )
(    2.01    0.44091    0.1    )
(    2    0.44283    0.1    )
(    1.99    0.44452    0.1    )
(    1.97    0.44721    0.1    )
(    1.95    449    0.1    )
(    1.93    0.44989    0.1    )
/*(1.92    0.45    0.1)
(1.93    0.44989    0.1)
(1.94    0.44956    0.1)
(1.95    449    0.1)
(1.97    0.44721    0.1)
(1.98    0.44598    0.1)
(1.99    0.44452    0.1)
(2    0.44283    0.1)
(2.01    0.44091    0.1)
(2.02    0.43875    0.1)
(2.03    0.43635    0.1)
(2.04    0.4337    0.1)
(2.05    0.43081    0.1)
(2.06    0.42767    0.1)
(2.07    0.42426    0.1)
(2.08    0.42059    0.1)
(2.09    0.41665    0.1)
(2.1    0.41243    0.1)
(2.11    0.40792    0.1)
(2.12    0.40311    0.1)
(2.13    0.39799    0.1)
(2.14    0.39256    0.1)
(2.15    0.38678    0.1)
(2.16    0.38066    0.1)
(2.17    0.37417    0.1)
(2.18    0.36729    0.1)
(2.19    0.36    0.1)
(2.2    0.35228    0.1)
(2.21    0.34409    0.1)
(2.22    0.33541    0.1)
(2.23    0.32619    0.1)
(2.24    0.31639    0.1)
(2.25    0.30594    0.1)
(2.26    0.29479    0.1)
(2.27    0.28284    0.1)
(2.28    0.27    0.1)
(2.29    0.25612    0.1)
(2.3    0.24104    0.1)
(2.31    0.2245    0.1)
(2.32    0.20616    0.1)
(2.33    0.18547    0.1)
(2.34    0.16155    0.1)
(2.35    0.13266    0.1)
(2.36    0.09434    0.1)
(2.37    0    0.1)*/
perhaps I made an mistake, but I don't find it.
Old   January 28, 2010, 16:50
Andreas Jörg
Now the big problem. SonicFoam doesn't work, even in the case which is meshed like I wanted it to. It gives the following errormessage
Starting time loop
Time = 1e-05
Courant Number mean: 22.7905 max: 3235.72
diagonal:  Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0
#0  Foam::error::printStack(Foam::Ostream&) in "/home/andreas/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so"
#1  Foam::sigFpe::sigFpeHandler(int) in "/home/andreas/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so"
#2  ?? in "/lib/libc.so.6"
#3  void Foam::fvc::surfaceIntegrate<Foam::Vector<double> >(Foam::Field<Foam::Vector<double> >&, Foam::GeometricField<Foam::Vector<double>, Foam::fvsPatchField, Foam::surfaceMesh> const&) in "/home/andreas/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libfiniteVolume.so"
#4  Foam::tmp<Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> > Foam::fvc::surfaceIntegrate<Foam::Vector<double> >(Foam::GeometricField<Foam::Vector<double>, Foam::fvsPatchField, Foam::surfaceMesh> const&) in "/home/andreas/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libfiniteVolume.so"
#5  Foam::tmp<Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> > Foam::fvc::surfaceIntegrate<Foam::Vector<double> >(Foam::tmp<Foam::GeometricField<Foam::Vector<double>, Foam::fvsPatchField, Foam::surfaceMesh> > const&) in "/home/andreas/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libfiniteVolume.so"
#6  Foam::fv::gaussDivScheme<Foam::Tensor<double> >::fvcDiv(Foam::GeometricField<Foam::Tensor<double>, Foam::fvPatchField, Foam::volMesh> const&) in "/home/andreas/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libfiniteVolume.so"
#7  Foam::tmp<Foam::GeometricField<Foam::innerProduct<Foam::Vector<double>, Foam::Tensor<double> >::type, Foam::fvPatchField, Foam::volMesh> > Foam::fvc::div<Foam::Tensor<double> >(Foam::GeometricField<Foam::Tensor<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::word const&) in "/home/andreas/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libcompressibleRASModels.so"
#8  Foam::tmp<Foam::GeometricField<Foam::innerProduct<Foam::Vector<double>, Foam::Tensor<double> >::type, Foam::fvPatchField, Foam::volMesh> > Foam::fvc::div<Foam::Tensor<double> >(Foam::GeometricField<Foam::Tensor<double>, Foam::fvPatchField, Foam::volMesh> const&) in "/home/andreas/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libcompressibleRASModels.so"
#9  Foam::compressible::RASModels::LaunderSharmaKE::divDevRhoReff(Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>&) const in "/home/andreas/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libcompressibleRASModels.so"
#10  main in "/home/andreas/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/sonicFoam"
#11  __libc_start_main in "/lib/libc.so.6"
#12  _start at /usr/src/packages/BUILD/glibc-2.9/csu/../sysdeps/x86_64/elf/start.S:116
Floating point exception
seems to be a little cryptic to me, but I assume that it is due to the mesh. So I run checkMesh
Create polyMesh for time = 0
Time = 0
Mesh stats
    internal points:  0
    faces:            160400
    internal faces:   79600
    cells:            40000
    boundary patches: 6
    point zones:      0
    face zones:       0
    cell zones:       0
Overall number of cells of each type:
    hexahedra:     40000
    prisms:        0
    wedges:        0
    pyramids:      0
    tet wedges:    0
    tetrahedra:    0
    polyhedra:     0
Checking topology...
    Boundary definition OK.
    Point usage OK.
    Upper triangular ordering OK.
    Face vertices OK.
    Number of regions: 1 (OK).
Checking patch topology for multiply connected surfaces ...
    Patch               Faces    Points   Surface topology
    phoenix             400      800      ok (non-closed singly connected)
    inlet               100      202      ok (non-closed singly connected)
    outlet              100      202      ok (non-closed singly connected)
    top                 100      202      ok (non-closed singly connected)
    bottom              100      202      ok (non-closed singly connected)
    frontback           80000    80800    ok (non-closed singly connected)
Checking geometry...
    Overall domain bounding box (0 0 0) (2.5 1 0.1)
    Mesh (non-empty, non-wedge) directions (1 1 0)
    Mesh (non-empty) directions (1 1 0)
    All edges aligned with or perpendicular to non-empty directions.
    Boundary openness (-6.09642e-18 -1.90675e-17 -4.10049e-16) OK.
 ***High aspect ratio cells found, Max aspect ratio: 3.62059e+197, number of cells 24064
  <<Writing 24064 cells with high aspect ratio to set highAspectRatioCells
    Minumum face area = 3.7867e-11. Maximum face area = 0.0161903.  Face area magnitudes OK.
    Min volume = 2e-300. Max volume = 0.000162921.  Total volume = 0.234227.  Cell volumes OK.
    Mesh non-orthogonality Max: 179.936 average: 89.7278
   *Number of severely non-orthogonal faces: 18835.
 ***Number of non-orthogonality errors: 39972.
  <<Writing 58807 non-orthogonal faces to set nonOrthoFaces
 ***Error in face pyramids: 120186 faces are incorrectly oriented.
  <<Writing 80519 faces with incorrect orientation to set wrongOrientedFaces
 ***Max skewness = 8249.46, 270 highly skew faces detected which may impair the quality of the results
  <<Writing 270 skew faces to set skewFaces
Failed 4 mesh checks.
End
I don't know how it is possible to fix this error.
Old   January 28, 2010, 21:29
Jinbiao Xiong
Originally Posted by Andyjoe View Post
Hi Jinbiao,
Hi Andreas,
Yes, I have tried to view the mesh with paraView. But the paraview doesnot work anyway. When I press "apply", the paraview just exited automatically. I donot know why.
But when I neglect the warning, just run the case. I can obtain the result. And I can view the result using paraView. This problem is very confusing. Do you have any idea?
Regards
Jinbiao
Old   January 28, 2010, 21:44
Ahmed
Ahmed is on a distinguished road
Andreas Jörg
This is the first line of your error log
Look the definition of the Courant number and see how it could be knocked down to be less or equal to One
when you get time, read about the physical meaning of the Courant Number
Ahmed is offline   Reply With Quote
Old   January 28, 2010, 22:06
Andreas Jörg
Thank you, Ahmed, that could solve the Problem. So my time step is too big, or my meshside too small.
JinBiao: Are you satisfied with the result of the simulation? I think, if the error in blockMesh isn't fatal it still could leed to results. ParaView doesn't work very well on my linux PC too. Under windows its more stable, in my case. Have you tried, to convert the files first "foamToVTK", then starting paraview and now loading the VTK file? For some reason on my pc this works better than using "paraFoam".
So for me the remaining problems are why I cant define more points and how to do the wedge.
Old   January 29, 2010, 00:34
Andreas Jörg
I decreased the time-step and the maximal Courant number was about 0.3, but the same error occured.
Old   January 29, 2010, 03:37
Jinbiao Xiong
Andreas, thanks for you reply. foamToVTK works for me.
I think in your case you may still have some problem in the mesh. If I am right, I notice that in the beginning you defined the wedges in one patch. It seems not a proper way to do so. Please try to define it separately.
I hope this helps.
Regards,
Jinbiao
Changing the grid on the same set-up Katya FLUENT 7 October 8, 2009 17:31
[ICEM] Surface Meshing Problems - Need Help Jules ANSYS Meshing & Geometry 3 May 11, 2009 10:31
FloWizard - problems in meshing Mark FLUENT 0 June 21, 2006 06:55
Problems with gambit meshing Aussie Shane FLUENT 1 May 4, 2006 08:18
Singularity of grid?Volume meshing vs face meshing Ken Main CFD Forum 0 September 4, 2003 12:09
