Solving the total energy equation
Like Tree21Likes
Old   June 13, 2014, 00:07
fairuz
fairuz is on a distinguished road
Originally Posted by cliffoi View Post
Hi all,
I have spent some time looking at this and finally implemented the total enthalpy equation as follows:
volScalarField Ek = 0.5*magSqr(U);
htot = h + Ek;
htot.correctBoundaryConditions();
solve
fvm::ddt(rho, htot)
+ fvm::div(phi, htot)
- fvm::laplacian(turbulence->alphaEff(), htot)
+ fvc::laplacian(turbulence->alphaEff(), Ek)
fvc::ddt(p)
+ fvc::div(tau & U, "div((muEff*dev(twoSymm(fvc::grad(U))))&U)")
h = htot - Ek;
h.correctBoundaryConditions();
Here tau is the stress tensor. Even though it's small I have included it in my solver.
Note that the total enthalpy requires customized boundaries, like the gradientEnthalpyFvPatchScalarField and similar classes supplied in thermophysicalModels to get consistent solutions.
The solutions from this implementation are looking pretty good.
Going back to my previous comment, if we use enthalpy we don't have to worry about whether turbulence->alphaEff() is applicable.
Hi Ivor
So doing this is sufficient enough?Do u have done any other modification in order to correct the boundary condition?
fairuz is offline   Reply With Quote
Old   June 13, 2014, 01:44
Ivor Clifford
cliffoi is on a distinguished road
I typically use custom boundaries for a problem like this since often we're looking to fix a temperature, velocity, heat flux or apply some other heat source/sink at the boundary, and we need to supply expressions for total enthalpy in terms of these variables . This is no different from what OpenFOAM already does for the enthalpy equation... I just customized it for my specific case.
I have attached the boundary I use that takes the temperature and velocity boundaries conditions and defines the total enthalpy in terms of these.
Regards
Ivor
cliffoi is offline   Reply With Quote
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 16:33
Error log vw.cfd OpenFOAM 6 August 7, 2009 06:44
Differences between serial and parallel runs carsten OpenFOAM Bugs 11 September 12, 2008 12:16
Unknown error sivakumar OpenFOAM Pre-Processing 9 September 9, 2008 13:53
Why FVM for high-Re flows? Zhong Lei Main CFD Forum 23 May 14, 1999 14:22
