Placing a heat source in an airconditioned room |
January 22, 2010, 17:59 |
Robin Gilbert
Rep Power: 16 |
Hello guys,
I was trying to simulate multiple heat sources inside an airconditioned room (which means that there is an inlet and an outlet for air in the room). i tried using rhoPimpleFoam but i doubt if the results are right. I want to study the flow of heat from the heat sources to its surroundings. What solver should i use? is rhoPimpleFoam sufficient? |
January 23, 2010, 16:13 |
Robin Gilbert
Rep Power: 16 |
it would be really helpful if somebody could answer my question.
Thanks |
January 24, 2010, 07:50 |
James Nally
Rep Power: 17 |
I would check out the heat transfer solvers, eg buoyantPisoFoam
all of them can be found in "OpenFOAM/OpenFOAM-1.6/applications/solvers/heatTransfer/" and see if there is something there which suits your needs, the main source file will have a description of the solver near the top. |
compressible flow, heat source, hvac, rhopimplefoam |
Version 15 on Mac OS X | gschaider | OpenFOAM Installation | 113 | December 2, 2009 11:23 |
DxFoam reader update | hjasak | OpenFOAM Post-Processing | 69 | April 24, 2008 02:24 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 18:51 |
UDF Scalar Code: HT 1 | Greg Perkins | FLUENT | 8 | October 20, 2000 13:40 |
UDFs for Scalar Eqn - Fluid/Solid HT | Greg Perkins | FLUENT | 0 | October 14, 2000 00:03 |
