Problem with cyclic bc when run on parallel
Old   January 18, 2010, 01:06
Default Problem with cyclic bc when run on parallel
Tek
New guy
Tek is on a distinguished road
Hi everyone!
I'm a novice with openfoam.I try to run two channelFoam case (one for mesh constructed from block mesh,other for mesh converted from fluentMeshtoFoam) with cyclic BC.When i run parallel with the first one with many kind of decomposePar there is no problem.But it happen when i run parallel with the second one.It print to the screen " create Mesh for time = 0" and stop ,i wait for long time but nothing happen.
I hope somebody whose experience with this problem can help me.
Thanks to reading and sorry about my English.
Tek is offline   Reply With Quote
Old   January 18, 2010, 05:57
Tek
New guy
does everyone has an idear ?What's problem with cyclic bc when decomposePar? I guest it's relevant with reading Mesh but i still don't understand...
everyhelp is appriciate!!
Old   January 20, 2011, 15:40
Default I don't think it's due to cycle bc
Charlie
cheng1988sjtu is on a distinguished road
Hi Tek,
I've just started to run the channelFoam, and run parallel, it seems OK, even though I have cycle BC in the domain, so maybe it's due to the conversion from Fluent to OpenFoam.
Perhaps, some boundary type has changed? you may check it,
Good luck~
Zhen
cheng1988sjtu is offline   Reply With Quote
Script to Run Parallel Jobs in Rocks Cluster asaha OpenFOAM Running, Solving & CFD 12 July 4, 2012 23:51
Cannot run Star-CCM+ parallel in Linux dburns Siemens 9 April 27, 2010 13:01
problem specifying alpha at inlet during a parallel run phsieh2005 OpenFOAM Running, Solving & CFD 2 August 13, 2009 09:23
Problem on Parallel Run Setup Hamidur Rahman CFX 0 September 23, 2007 18:11
Serial run OK parallel one fails r2d2 OpenFOAM Running, Solving & CFD 2 November 16, 2005 13:44
