December 28, 2009, 06:39 |
Mapping results on points
Rep Power: 16 |
I would like to map results on geometrical points on my boundaries. These results are written in fluent "profile" format, however I could translate the point coordinates and the results to another format as a previous step. Has somebody tried something similar before? Thanks in avance. Codina |
January 5, 2010, 11:36 |
Aniko Rakai
Rep Power: 17 |
I'm not sure if I understand well your problem but have you tried sampleDict? According to user guide U-169 this is for sampling data in 1D profiles.
January 11, 2010, 07:19 |
Rep Power: 16 |
Thank you Ancsa,
After reviewing the user guide documentation, I understand that the sampleDict is used to get results on an arbitrary surface (defined by points), isn't it? I am trying to do the contrary, I mean sampling results, which may come from another code, on the walls and impose these values as boundary conditions. It is the same idea of mapFields, however the input data is defined on discrete points instead of cells or faces. Codina |
January 15, 2010, 10:40 |
Aniko Rakai
Rep Power: 17 |
Hi Codina,
I'm sorry I'm too newbie to be able to help you in that, search the forum, boundary conditions can be defined by funkySetFields and with timeVaryingMappedFixedValue but I haven't tried them yet. |
January 15, 2010, 11:00 |
Rep Power: 16 |
Thank you,
I'ill have a look at these utilities and I'ill give you feedback. |
Mapping CFD results into FEA | chittoorreddy | STAR-CCM+ | 5 | August 17, 2009 05:18 |
Results mapping. | paka | FLUENT | 1 | March 20, 2009 02:49 |
[blockMesh] BlockMeshmergePatchPairs | hjasak | OpenFOAM Meshing & Mesh Conversion | 11 | August 15, 2008 08:36 |
mapping of pressure results | venu | FLUENT | 0 | May 5, 2005 10:37 |
[Gmsh] Import gmsh msh to Foam | adorean | OpenFOAM Meshing & Mesh Conversion | 24 | April 27, 2005 09:19 |
