droplet simulation over flat plate
Old   December 24, 2009, 11:04
Default droplet simulation over flat plate
openfoam1 is on a distinguished road
Hello foamers
I want to simulate droplet motion over hydrophobic flat plate under the effect of some forces (wind force , centrifugal force) using openfoam ,, any suggestions
thank you for your help
openfoam1 is offline   Reply With Quote
Old   December 25, 2009, 02:48
firstly i make a simulation of laminar flow over a sphere using snappyHexMesh utility and icoFoam solver , like in that photo
I have to rest that sphere on the lower wall (which is not a big deal )
just change the .stl file ..
now ,I'm asking for the following :
1) how to make the sphere's mesh dynamic (the droplet should move on the lower wall under influence of air drag and centrifugal force)
2) how to make the sphere's mesh free surface mesh
3) how to capture the surface tension effects of the droplet near wall or near air
thank you ..
Old   December 26, 2009, 00:29
is it a hard case ? or it need new solver to be programmed !!
any one know , please tell me
i don't have the programming capability to make a new solver
thank you
Old   December 28, 2009, 10:55
Sandeep Menon
deepsterblue will become famous soon enough
What you're looking for is the interTrackFoam solver. Take a look at the hydrofoil tutorial.. That should help you set up a test case.
Sandeep Menon
University of Massachusetts Amherst
https://github.com/smenon
deepsterblue is offline   Reply With Quote
Old   May 3, 2010, 19:25
farhagim is on a distinguished road
could you do that simulation. can you help me to simulate such a droplet??
thanks,
thank you
farhagim is offline   Reply With Quote
Old   May 4, 2010, 06:39
Elvis
elvis will become famous soon enough
take a look at
http://powerlab.fsb.hr/ped/kturbo/Op..._30Nov2008.tgz
and try to get it to work on your installation as a starter.
I am not an expert in this topic, but I believe you will have to understand and work with the finite area method that is implemented in OpenFOAM.
Sorry that I can not help you more.
elvis
elvis is offline   Reply With Quote
Old   May 4, 2010, 15:21
hi,
thanks for your response elvis...I have installed OpenFoam1.6 on my computer. I think this file which you gave me is not compatible with my version. Would you please tell me how to fix it.
for example..it can not recognize alpha1 or U or P...I think these variable is defined by other names like gamma, pd ...in OF1.4 am i right?
Thanks for your help elvis,
Mehran
Originally Posted by elvis View Post
take a look at
elvis
Old   May 5, 2010, 05:16
lord_kossity's Avatar
Andreas Dietz
lord_kossity is on a distinguished road
Hey Mehran,
OpenFOAM-1.6 is the wrong choice.
If you want to use the interTrackFoam solver, you will have to install OpenFOAM-1.5-dev (from here: http://openfoam-extend.svn.sourcefor...nd/trunk/Core/).
Best,
Andreas
lord_kossity is offline   Reply With Quote
Old   May 5, 2010, 14:19
Hey, you mean for using the InterFoam solver, it s better to install the old version instead of OF1.6??
is this a better version version of OF?
Thanks for your response.
Mehran
Originally Posted by lord_kossity View Post
Hey Mehran,
Best,
Andreas
Old   May 6, 2010, 14:59
Andreas Dietz
Since you were talking about a moving mesh or at least about FAM (Finite Area Method) you will need interTrackFoam. This solver is only released in the previous mentioned OpenFOAM-1.5-dev.
In case of you now try to solve your issue with interFoam (no moving mesh, no FAM --> mesh is not fitted to the interface) you can either use 1.5-dev or 1.6. Which one is "better", I cannot say. I think it is almost the same - at least the method is equal.
Old   May 10, 2010, 12:47
Thanks for your response..I will try this version...
Old   December 16, 2010, 09:45
hossein
hossein.mashhadi is on a distinguished road
thank you ..
hi
to openfoam1
i wanna learn using OpenFOAM software and i want to solve the cross flow over sphere problem which you have solved above. but i m not familiar with snappyhexmesh so i can not create a spherical mesh.
can you help me?
thanks
hossein.mashhadi is offline   Reply With Quote
DNS for Impinging Jet on a Flat Plate Chandra Shekhar Main CFD Forum 3 January 18, 2010 06:03
Questions about a Turbulent Flat Plate Case tstorm FLUENT 2 August 11, 2009 15:16
Not getting Simple flat plate simulation using sonicTurbFoam velan OpenFOAM Running, Solving & CFD 1 September 19, 2008 06:00
entrance of a flat plate mc Main CFD Forum 0 April 24, 2007 23:38
simulation of flat plate cisong FLUENT 4 September 12, 2001 12:10
