buoyantBoussinesqPisoFoam can't use LES model ?
Old   December 20, 2009, 22:19
Default buoyantBoussinesqPisoFoam can't use LES model ?
Jiang
panda60 is on a distinguished road
Dear all:
I want do the simulation of imcompressible flow with buoyancy effect.
but I saw buoyantBoussinesqPisoFoam only can use RAS model, can select LES model. Am I right ?
Thank you very much.
panda60 is offline   Reply With Quote
Old   December 30, 2009, 18:41
Matthew J. Churchfield
mchurchf is on a distinguished road
That is correct. I have had to modify buoyantBoussinesqPisoFoam to be able to utilize LES models. You can look at pisoFOAM and follow its coding to do the modification.
mchurchf is offline   Reply With Quote
Implementing a new LES Model in OpenFoam fs82 OpenFOAM 6 October 13, 2009 10:58
help urgent LES model for a swimming pool marion FLUENT 0 June 4, 2007 06:26
the stability of compressilbe flow using LES model ricklee Main CFD Forum 0 August 27, 2005 15:33
Anisotropic subgrid model (LES) h.jordi Main CFD Forum 1 August 29, 2002 16:49
LES pipe model Matt FLUENT 1 August 21, 2002 15:19
