plz have a look -error time dependent inlet conditions
Old   December 18, 2009, 05:35
Default plz have a look -error time dependent inlet conditions
heavy_user is on a distinguished road
Hi There,
I am trying to have a time dependent inlet-condition.
I used the information from the threat "TimeVaryingUniformFixedValue".
(I want the velocity to raise, since pressure corretion messes up when i start up with the high velocity).
But I am stuck somehow...since I dont know how to deal with the error message.
Create mesh for time = 0
Reading g
Reading thermophysical properties
Reading field T
Reading field p
Reading field U
Expected a '(' while reading VectorSpace<Form, Cmpt, nCmpt>, found on line 27 the doubleScalar 100000
file: /home/OpenFOAM/OpenFOAM-1.6/OWN/jetflame/V4/0/U::value at line 27.
From function Istream::readBegin(const char*)
in file db/IOstreams/IOstreams/Istream.C at line 87.
FOAM exiting
the .dat file:
( 0.00005 ( 0 0 0.1000 ) )
( 0.00010 ( 0 0 0.2058 ) )
( 0.00015 ( 0 0 0.3116 ) )
( 0.00020 ( 0 0 0.4174 ) )
( 0.00025 ( 0 0 0.5232 ) )
( 0.00030 ( 0 0 0.6290 ) )
( 0.00035 ( 0 0 0.7348 ) )
( 0.00040 ( 0 0 0.8406 ) )
( 0.00045 ( 0 0 0.9464 ) )
( 0.00050 ( 0 0 1.0522 ) )
( 0.00055 ( 0 0 1.1580 ) )
( 0.00060 ( 0 0 1.2638 ) )
( 0.00065 ( 0 0 1.3696 ) )
( 0.00070 ( 0 0 1.4754 ) )
( 0.00075 ( 0 0 1.5812 ) )
( 0.00080 ( 0 0 1.6870 ) )
( 0.00085 ( 0 0 1.7928 ) )
( 0.00090 ( 0 0 1.8986 ) )
( 0.00095 ( 0 0 2.0044 ) )
( 0.00100 ( 0 0 2.1102 ) )
( 0.00105 ( 0 0 2.2160 ) )
( 0.00110 ( 0 0 2.3218 ) )
( 0.00115 ( 0 0 2.4276 ) )
( 0.00120 ( 0 0 2.5334 ) )
( 0.00125 ( 0 0 2.6392 ) )
( 0.00130 ( 0 0 2.7450 ) )
( 0.00135 ( 0 0 2.8508 ) ) // line 27 (starting to count from 0)
( 0.00140 ( 0 0 2.9566 ) )
( 0.00145 ( 0 0 3.0624 ) )
( 0.00150 ( 0 0 3.1682 ) )
( 0.00155 ( 0 0 3.2740 ) )
( 0.00160 ( 0 0 3.3798 ) )
( 0.00165 ( 0 0 3.4856 ) )
( 0.00170 ( 0 0 3.5914 ) )
( 0.00175 ( 0 0 3.6972 ) )
( 0.00180 ( 0 0 3.8030 ) )
( 0.00185 ( 0 0 3.9088 ) )
( 0.00190 ( 0 0 4.0146 ) )
( 0.00195 ( 0 0 4.1204 ) )
I cant find a missing "(" and there is no value "100000" ->
Any Ideas????
regards
heavy_user is offline   Reply With Quote
Old   December 18, 2009, 07:48
Julien Schaguene
Schag is on a distinguished road
"Expected a '(' while reading VectorSpace<Form, Cmpt, nCmpt>, found on line 27 the doubleScalar 100000
file: /home/OpenFOAM/OpenFOAM-1.6/OWN/jetflame/V4/0/U::value at line 27."
The Error is in the 0/U file, maybe you can show us this one.
Schag is offline   Reply With Quote
Old   December 18, 2009, 08:35
Hi Schag,
thx for the answer!!
Ich checked the U file again and tryed things... now it seems to work...(but i ran into other probs , thats why it is called CFD (coloured frustration dynamics :-) ) )
I used the information from:
http://www.idurun.com/?p=506
Where they use:
inlet
type timeVaryingUniformFixedValue;
timeDataFileName "inlet.dat";
value uniform 1e5;
I used:
inlet-gas
fileName "inlet.dat";
value uniform 1e5;
outOfBounds clamp;
OF seems not to like :
value uniform 1e5;
I removed it and now it seems to be running..
THX a lot!
P.S.:
I had to add the
outOfBounds clamp;
to continue simulation after specified data from "input.dat"..
i found info here : http://albertopassalacqua.com/?p=69
Velocity inlet boundary conditions abm FLUENT 16 October 18, 2014 09:52
recomendations for impellor inlet conditions PaulBosauder Main CFD Forum 0 August 4, 2009 18:57
time dependent inlet subroutine. HELP!!! jimmer Siemens 4 November 10, 2008 09:49
user soubroutine of inlet boundary conditions Charlie Beghein Siemens 2 August 30, 2002 03:03
Inlet and Outlet Boundary conditions for LES Jan Ramboer Main CFD Forum 12 August 6, 1999 23:00
