December 10, 2010, 03:26 |
#21 |
Stefano Wahono
Rep Power: 16 |
Good day, Alberto!
I have just built OF 1.7.1 on my machine, and run unmodified simpleFoam on the case. The exact same thing happened - crashed on the 2nd iter - exact same error msg. I'm using gcc 4.4.3. Actually, does the error msg look meaningful to you? Can we decipher this error message? Code:
#0 Foam::error::printStack(Foam::Ostream&) in "/home/stefano/OpenFOAM/OpenFOAM-1.7.1/lib/linuxGccDPOpt/libOpenFOAM.so" #1 Foam::sigFpe::sigFpeHandler(int) in "/home/stefano/OpenFOAM/OpenFOAM-1.7.1/lib/linuxGccDPOpt/libOpenFOAM.so" #2 Uninterpreted: #3 Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) in "/home/stefano/OpenFOAM/OpenFOAM-1.7.1/lib/linuxGccDPOpt/libOpenFOAM.so" #4 void Foam::divide<Foam::fvPatchField, Foam::volMesh>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) in "/home/stefano/OpenFOAM/OpenFOAM-1.7.1/lib/linuxGccDPOpt/libincompressibleRASModels.so" If it's not too much of a hassle for you, could you please email me your groovyBC source code. I may have a corrupted version? Thank you, Alberto! I very much appreciate it. Kind Regards, Stefano |
December 10, 2010, 11:14 |
#22 | |
Alberto Passalacqua
Rep Power: 36 |
I used this version: Code:
svn checkout https://openfoam-extend.svn.sourcefo...aries/groovyBC Alberto
Alberto Passalacqua GeekoCFD - A free distribution based on openSUSE 64 bit with CFD tools, including OpenFOAM. Available as in both physical and virtual formats (current status: http://albertopassalacqua.com/?p=1541) OpenQBMM - An open-source implementation of quadrature-based moment methods. To obtain more accurate answers, please specify the version of OpenFOAM you are using. |
December 13, 2010, 20:06 |
#23 |
Stefano Wahono
Rep Power: 16 |
Thank you, Alberto.
Unfortunately I can't use SVN at work computer due to a proxy. I downloaded the groovyBC source code through the web portal. I'll try downloading it later. Thanks again for all your help. Kind Regards, Stefano |
December 14, 2010, 00:38 |
#24 | |
Alberto Passalacqua
Rep Power: 36 |
http://dl.dropbox.com/u/659842/groovyBC.tar.gz Notice that you might have to run wclean before wmake, since it was built on my machine. Where do I send the bill? Best,
December 14, 2010, 01:29 |
#25 | |
Stefano Wahono
Rep Power: 16 |
What is your hourly rate? You can send it to the Australian Govt (my employer) What I can do to repay you is to pass everything I've learned about OF on to other people who are in the same position as me - struggling with OpenFOAM. Ok, I have re-made your groovyBC wclean wmake libso It returned errors (see error msg below), but I think it still compiled the library. - I may have gotten the same error message before, but ignored it because the library and BC type is still recognized by OpenFOAM despite the compilation error msg. - I checked both the GCC version and bison version installed on my machine is as required by groovyBC gcc (Ubuntu 4.4.3-4ubuntu5) 4.4.3 bison (GNU Bison) 2.4.1 The simulation still crashed on the second iteration using your copy of the newly compiled groovyBC. Just wondering if you had the same error msg (-See below) as me when you compiled the groovyBC on your machine? Thanks, Alberto! Kind Regards, Stefano The compilation error msg: Code:
$ wmake libso Making dependency list for source file PatchValueExpressionParser.yy Making dependency list for source file PatchResult.C Making dependency list for source file PatchValueExpressionLexer.ll Making dependency list for source file PatchValueExpressionDriver.C Making dependency list for source file groovyBCFvPatchFields.C could not open file PatchValueExpressionParser.tab.hh for source file PatchValueExpressionDriver.C could not open file PatchValueExpressionParser.tab.hh for source file PatchValueExpressionParser.yy could not open file PatchValueExpressionParser.tab.hh for source file PatchValueExpressionLexer.ll Making dependency list for source file groovyBCPointPatchFields.C could not open file MixedPointPatchField.H for source file groovyBCPointPatchFields.C could not open file PatchValueExpressionParser.tab.hh for source file groovyBCFvPatchFields.C could not open file PatchValueExpressionParser.tab.hh for source file groovyBCPointPatchFields.C could not open file PointPatchFieldMapper.H for source file groovyBCPointPatchFields.C SOURCE=PatchResult.C ; g++ -m32 -Dlinux -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -IMake/linuxGccDPOpt -I/home/stefano/OpenFOAM/OpenFOAM-1.7.1/src/finiteVolume/lnInclude -IlnInclude -I. -I/home/stefano/OpenFOAM/OpenFOAM-1.7.1/src/OpenFOAM/lnInclude -I/home/stefano/OpenFOAM/OpenFOAM-1.7.1/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linuxGccDPOpt/PatchResult.o SOURCE=PatchValueExpressionLexer.ll ; rm Make/linuxGccDPOpt/PatchValueExpressionLexer.C ; flex -f $SOURCE ; mv *.c Make/linuxGccDPOpt/PatchValueExpressionLexer.C ; g++ -m32 -Dlinux -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -IMake/linuxGccDPOpt -I/home/stefano/OpenFOAM/OpenFOAM-1.7.1/src/finiteVolume/lnInclude -IlnInclude -I. -I/home/stefano/OpenFOAM/OpenFOAM-1.7.1/src/OpenFOAM/lnInclude -I/home/stefano/OpenFOAM/OpenFOAM-1.7.1/src/OSspecific/POSIX/lnInclude -fPIC -c Make/linuxGccDPOpt/PatchValueExpressionLexer.C -o Make/linuxGccDPOpt/PatchValueExpressionLexer.o SOURCE=PatchValueExpressionParser.yy ; rm -f Make/linuxGccDPOpt/PatchValueExpressionParser.C Make/linuxGccDPOpt/PatchValueExpressionParser.tab.hh; bison -ra -v -d $SOURCE ; mv *.tab.cc Make/linuxGccDPOpt/PatchValueExpressionParser.C ; mv *.tab.hh Make/linuxGccDPOpt/PatchValueExpressionParser.tab.hh ; mv *.hh Make/linuxGccDPOpt ; g++ -m32 -Dlinux -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -IMake/linuxGccDPOpt -I/home/stefano/OpenFOAM/OpenFOAM-1.7.1/src/finiteVolume/lnInclude -IlnInclude -I. -I/home/stefano/OpenFOAM/OpenFOAM-1.7.1/src/OpenFOAM/lnInclude -I/home/stefano/OpenFOAM/OpenFOAM-1.7.1/src/OSspecific/POSIX/lnInclude -fPIC -c Make/linuxGccDPOpt/PatchValueExpressionParser.C -o Make/linuxGccDPOpt/PatchValueExpressionParser.o SOURCE=PatchValueExpressionDriver.C ; g++ -m32 -Dlinux -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -IMake/linuxGccDPOpt -I/home/stefano/OpenFOAM/OpenFOAM-1.7.1/src/finiteVolume/lnInclude -IlnInclude -I. -I/home/stefano/OpenFOAM/OpenFOAM-1.7.1/src/OpenFOAM/lnInclude -I/home/stefano/OpenFOAM/OpenFOAM-1.7.1/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linuxGccDPOpt/PatchValueExpressionDriver.o rm: cannot remove `Make/linuxGccDPOpt/PatchValueExpressionLexer.C': No such file or directory In file included from PatchValueExpressionDriver.H:59, from PatchValueExpressionDriver.C:34: PatchValueExpressionParser.tab.hh:44:20: error: stack.hh: No such file or directory lex.ve.c:372: warning: use of old-style cast lex.ve.c:442: warning: use of old-style cast lex.ve.c:442: warning: use of old-style cast PatchResult.C: In member function ‘void Foam::PatchResult::uglyDelete()’: PatchResult.C:95: warning: deleting ‘void*’ is undefined In file included from location.hh:44, from PatchValueExpressionParser.tab.hh:65, from PatchValueExpressionDriver.H:59, from PatchValueExpressionDriver.C:34: position.hh: In function ‘bool pve::operator==(const pve::position&, const pve::position&)’: position.hh:136: warning: suggest parentheses around ‘&&’ within ‘||’ In file included from PatchValueExpressionDriver.H:59, from PatchValueExpressionDriver.C:34: PatchValueExpressionParser.tab.hh: At global scope: PatchValueExpressionParser.tab.hh:309: error: ISO C++ forbids declaration of ‘stack’ with no type PatchValueExpressionParser.tab.hh:309: error: expected ‘;’ before ‘<’ token PatchValueExpressionParser.tab.hh:311: error: ISO C++ forbids declaration of ‘stack’ with no type PatchValueExpressionParser.tab.hh:311: error: expected ‘;’ before ‘<’ token PatchValueExpressionParser.tab.hh:313: error: ISO C++ forbids declaration of ‘stack’ with no type PatchValueExpressionParser.tab.hh:313: error: expected ‘;’ before ‘<’ token PatchValueExpressionParser.tab.hh:316: error: ‘state_stack_type’ does not name a type PatchValueExpressionParser.tab.hh:318: error: ‘semantic_stack_type’ does not name a type PatchValueExpressionParser.tab.hh:320: error: ‘location_stack_type’ does not name a type In file included from Make/linuxGccDPOpt/location.hh:44, from PatchValueExpressionParser.tab.hh:65, from PatchValueExpressionParser.tab.cc:61: position.hh: In function ‘bool pve::operator==(const pve::position&, const pve::position&)’: position.hh:136: warning: suggest parentheses around ‘&&’ within ‘||’ In file included from Make/linuxGccDPOpt/location.hh:44, from PatchValueExpressionParser.tab.hh:65, from lnInclude/PatchValueExpressionDriver.H:59, from PatchValueExpressionLexer.ll:3: position.hh: In function ‘bool pve::operator==(const pve::position&, const pve::position&)’: position.hh:136: warning: suggest parentheses around ‘&&’ within ‘||’ lex.ve.c: In function ‘int pvelex(pve::PatchValueExpressionParser::semantic_type*, pve::location*, Foam::PatchValueExpressionDriver&)’: lex.ve.c:9465: warning: use of old-style cast lex.ve.c:9465: warning: use of old-style cast lex.ve.c:9482: warning: use of old-style cast lex.ve.c:9495: warning: use of old-style cast lex.ve.c:9962: warning: use of old-style cast lex.ve.c: In function ‘int yy_get_next_buffer()’: lex.ve.c:10141: warning: use of old-style cast lex.ve.c:10164: warning: use of old-style cast lex.ve.c:10177: warning: use of old-style cast lex.ve.c:10177: warning: use of old-style cast lex.ve.c:10198: warning: use of old-style cast lex.ve.c:10198: warning: use of old-style cast lex.ve.c:10223: warning: use of old-style cast lex.ve.c:10226: warning: use of old-style cast lex.ve.c:10226: warning: use of old-style cast lex.ve.c: In function ‘yy_state_type yy_get_previous_state()’: lex.ve.c:10261: warning: use of old-style cast lex.ve.c:10261: warning: use of old-style cast lex.ve.c: In function ‘int yyinput()’: lex.ve.c:10379: warning: use of old-style cast lex.ve.c: In function ‘yy_buffer_state* ve_create_buffer(FILE*, int)’: lex.ve.c:10478: warning: use of old-style cast lex.ve.c:10487: warning: use of old-style cast lex.ve.c: In function ‘void ve_delete_buffer(yy_buffer_state*)’: lex.ve.c:10513: warning: use of old-style cast lex.ve.c:10516: warning: use of old-style cast lex.ve.c:10518: warning: use of old-style cast lex.ve.c: In function ‘void veensure_buffer_stack()’: lex.ve.c:10685: warning: use of old-style cast lex.ve.c:10705: warning: use of old-style cast lex.ve.c: In function ‘yy_buffer_state* ve_scan_buffer(char*, yy_size_t)’: lex.ve.c:10733: warning: use of old-style cast lex.ve.c: In function ‘yy_buffer_state* ve_scan_bytes(const char*, int)’: lex.ve.c:10786: warning: use of old-style cast lex.ve.c: In function ‘void yy_push_state(int)’: lex.ve.c:10822: warning: use of old-style cast lex.ve.c:10825: warning: use of old-style cast lex.ve.c:10825: warning: use of old-style cast lex.ve.c: In function ‘int yy_init_globals()’: lex.ve.c:10992: warning: use of old-style cast lex.ve.c:11005: warning: use of old-style cast lex.ve.c:11006: warning: use of old-style cast lex.ve.c: In function ‘void* vealloc(yy_size_t)’: lex.ve.c:11072: warning: use of old-style cast lex.ve.c: In function ‘void* verealloc(void*, yy_size_t)’: lex.ve.c:11084: warning: use of old-style cast lex.ve.c:11084: warning: use of old-style cast lex.ve.c: In function ‘void vefree(void*)’: lex.ve.c:11089: warning: use of old-style cast SOURCE=groovyBCFvPatchFields.C ; g++ -m32 -Dlinux -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -IMake/linuxGccDPOpt -I/home/stefano/OpenFOAM/OpenFOAM-1.7.1/src/finiteVolume/lnInclude -IlnInclude -I. -I/home/stefano/OpenFOAM/OpenFOAM-1.7.1/src/OpenFOAM/lnInclude -I/home/stefano/OpenFOAM/OpenFOAM-1.7.1/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linuxGccDPOpt/groovyBCFvPatchFields.o make: *** [Make/linuxGccDPOpt/PatchValueExpressionDriver.o] Error 1 make: *** Waiting for unfinished jobs.... PatchValueExpressionParser.tab.cc: In member function ‘unsigned char pve::PatchValueExpressionParser::yytranslate_(int)’: PatchValueExpressionParser.tab.cc:4941: warning: use of old-style cast In file included from Make/linuxGccDPOpt/location.hh:44, from PatchValueExpressionParser.tab.hh:65, from PatchValueExpressionDriver.H:59, from groovyBCFvPatchField.H:48, from groovyBCFvPatchFields.H:37, from groovyBCFvPatchFields.C:36: position.hh: In function ‘bool pve::operator==(const pve::position&, const pve::position&)’: position.hh:136: warning: suggest parentheses around ‘&&’ within ‘||’ lex.ve.c: At global scope: lex.ve.c:10809: warning: ‘void yy_push_state(int)’ defined but not used lex.ve.c:10837: warning: ‘void yy_pop_state()’ defined but not used lex.ve.c:10849: warning: ‘int yy_top_state()’ defined but not used |
December 14, 2010, 03:11 |
#26 | ||
Alberto Passalacqua
Rep Power: 36 |
We all struggle with OpenFOAM because "documentation is not important!". A lost battle of years... Quote:
Best,
Neumann pressure BC and velocity field | Antech | Main CFD Forum | 0 | April 25, 2006 03:15 |
How to create Hemisphere Velocity Profile at inlet | Nelson | FLUENT | 0 | July 10, 2005 22:44 |
using profile to specify inlet VOF and velocity | yf | FLUENT | 8 | June 2, 2005 06:40 |
Inlet velocity profile | strudl | CFX | 0 | July 18, 2003 10:58 |
velocity more than INLET velocity | neu | FLUENT | 3 | May 13, 2003 05:56 |
