TwoPhaseEulerFoam bed tutorial case stable in 1.5, crashes in 1.6 |
December 2, 2009, 01:54 |
Rasmus Hemph
Rep Power: 17 |
I am having trouble with the solver twoPhaseEulerFoam in version 1.6.x. My cases now crashes frequently due to high volume fraction particles. This is both with and without kinetic theory. The same cases ran fine in 1.5. To illustrate the problem, try the 'bed' tutorial case, which crashes in 1.6.x and runs in 1.5. From running diff on the source files, I can see that turbulence inclusion changed between the versions. And indeed, running with turbulence turned off, allows the 'bed'-case to finish. Is anyone experiencing a change in stability for twoPhaseEulerFoam? Suggestions/explanations? Best regards, Rasmus |
December 2, 2009, 02:57 |
Fabian Peng Karrholm
Rep Power: 17 |
I've had the exact same problem. twoPhaseEulerFoam runs fine without the turbulence, but as soon as it is switched on it crashed after a few iterations. I tried the tutorial as well as more applied cases. Unfortunately, I haven't had the time to examine the problem further.
I assumed it was "SBS", but perhaps it wasn't so |
December 4, 2009, 02:33 |
Rasmus Hemph
Rep Power: 17 |
Ok. Glad to hear I am not the only one. Since the tutorial case does not run, I will put this issue on the bugs forum.
//Rasmus |
Is Playstation 3 cluster suitable for CFD work | hsieh | OpenFOAM | 9 | August 16, 2015 14:53 |
ChtMuliRegionFoam-Case (OF 1.6 Tutorial-case -> OF 1.5) | suitup | OpenFOAM | 15 | November 11, 2009 12:43 |
Forces in 1.5 with an Ahmed VWT case | terrybarnaby | OpenFOAM Running, Solving & CFD | 3 | June 9, 2009 08:21 |
FoamX refuses to open an interFoam tutorial case | vrecha | OpenFOAM Pre-Processing | 5 | March 12, 2008 12:36 |
Free surface boudary conditions with SOLA-VOF | Fan | Main CFD Forum | 10 | September 9, 2006 12:24 |
