incompressible, The exact meaning of P in case/0/p ?
Old   December 1, 2009, 23:27
Default incompressible, The exact meaning of P in case/0/p ?
Jiang
panda60 is on a distinguished road
Dear all:
For simpleFoam solver, what is the exzct meaning of P in case/0/P file ?
It is refference value or the actual value ?
for initial field and outlet condition , we should set 0 or 101325/rho ?
Because I saw many imcompressible case set it to 0, but I set 101325/rho .
Thank you very much.
panda60 is offline   Reply With Quote
Old   December 2, 2009, 00:44
Masashi Ohbuchi
Ohbuchi is on a distinguished road
There is no meaning for the value of p in incompressible flow. Only the gradient term of p is appeared in Navier-Stokes eq.
You can start both from p=0 or p=101324/rho, then simulated result may be translate by constant value.
Ohbuchi is offline   Reply With Quote
Old   December 2, 2009, 01:09
Jiang
Thanks Ohbuchi,
I am l little understand, I saw the solver of simpleFoam ,in creatfields,H
# include "createPhi.H"
label pRefCell = 0;
scalar pRefValue = 0.0;
setRefCell(p, mesh.solutionDict().subDict("SIMPLE"), pRefCell, pRefValue);
The solver will select the pressure reference possition and reference value itself, so I just set the actual value in P file, is it right ?
Old   December 2, 2009, 05:41
Masashi Ohbuchi
Yes, specified value for p in 0 directory means difference from reference value. So if you set the reference value of p=0, values in 0/p means absolute value.
Incompressible Ideal gas law Leverkin FLUENT 5 March 5, 2009 17:41
Abt: the speed of sound in incompressible flows jinwon park Main CFD Forum 3 August 21, 2008 21:44
LinearInterpolaterhoU amp meshSf exact meaning arkangel OpenFOAM Running, Solving & CFD 2 August 21, 2007 06:29
Reynold's number and incompressible flow Neil Main CFD Forum 3 October 24, 2006 09:11
Compressible vs. Incompressible formulations Fernando Velasco Hurtado Main CFD Forum 3 January 7, 2000 17:51
