Meshing a 3D model
Old   November 27, 2009, 14:03
Default Meshing a 3D model
Scott
scottneh is on a distinguished road
Hello Again
I'm curious if anyone has seen a good tutorial on how to mesh a 3D model. I have read the user manual but It doesn't have quite what I am looking for. I have a fin modeled in NX and coverted to STL format. I'm not sure how to tell the meshing tools what the orientation of the model is, i.e. where is the fixed base outside the flow, and which way X, Y and Z point. If anyone has seen a good tutorial on meshing 3D models I would really appreciate knowing about it.
Thanks
Scott
scottneh is offline   Reply With Quote
Old   November 28, 2009, 08:04
Elvis
elvis will become famous soon enough
If you use NX you should be able to write UNV (universal files) right?
So read the NX tutorials for Meshing write a UNV-file and run OF-Simulation
Openfoam comes with a converter => IdeasUnvToFoam
http://openfoamwiki.net/index.php/IdeasUnvToFoam take a look at part2,3 of the shockwaves, and make similar with NX
http://www.caelinux.org/wiki/index.p...ELinux_2007.29
good luck
elvis
elvis is offline   Reply With Quote
Old   November 28, 2009, 08:41
Elvis
Originally Posted by scottneh View Post
Hello Again
Thanks
Scott
Hi scott,
if you have STL, you can use snappyhexmesh (perhaps!)
http://www.tfd.chalmers.se/~hani/kur...on_2009_OP.pdf
anyway nice to get more information
http://www.tfd.chalmers.se/~hani/kurser/OS_CFD_2009/
http://www.tfd.chalmers.se/~hani/kurser/OS_CFD_2008/
http://www.tfd.chalmers.se/~hani/kurser/OS_CFD_2007/
on the other hand NX can create UNV-Files take a look how Salome creates UNV-File for Simulation an do same with NX
http://www.caelinux.org/wiki/downloa...7/PipeMesh.htm
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 06:36
Trimmer meshing model STAR-CCM+ rH Siemens 3 December 17, 2008 17:16
LES and combustion model Margherita Cadorin CFX 0 October 29, 2008 06:24
Vehicle CAD Model Meshing B Bru Siemens 5 June 8, 2007 18:30
model han Main CFD Forum 0 September 27, 2005 09:35
