problems with probes() function in chtMultiRegionFoam
Old   November 25, 2009, 16:08
Exclamation problems with probes() function in chtMultiRegionFoam
Victor Fleischer
Victor is on a distinguished road
Hi at all,
i have a problem with using the probes() function in the chtMultiRegionFoam Solver. After setting up my case with setSet, setsToZones, splitMeshRegions, i tried to use the probes() function. Then the following problem occured:
request for objectRegistry region0 from objectRegistry Test2_4 failed
available objects of type objectRegistry are
2
Stack
Fluid
Does anybody know how to solve this problem?
Or does anybody know an alternative for the probes() function without saving the whole data accumulated during the simulation?
here the additional part of the controlDict-File:
functions
probesTest
// Type of functionObject
type probes;
// Where to load it from (if not already in solver)
functionObjectLibs ("libsampling.so");
outputControl timeStep;
outputInterval 1;
// Locations to be probed. runTime modifiable!
probeLocations
( -0.05 0 0)
( -0.04 0 0)
( -0.03 0 0)
( -0.02 0 0)
( -0.01 0 0)
( 0.00 0 0)
( 0.01 0 0)
( 0.02 0 0)
( 0.03 0 0)
( 0.04 0 0)
( 0.05 0 0)
// Fields to be probed. runTime modifiable!
fields
rho
p
U
T
Victor is offline   Reply With Quote
LiencubiclowRemodel nzy102 OpenFOAM Bugs 14 January 10, 2012 09:53
Variable deltaT and functionObjects henrik OpenFOAM Bugs 8 July 22, 2009 05:11
Installation 1.5 as a user of server (New bird) chiven OpenFOAM Installation 15 April 26, 2009 23:33
[Commercial meshers] Several problems with the mesh conversion utility when converting the meshes from Gridgen su_junwei OpenFOAM Meshing & Mesh Conversion 2 July 27, 2008 00:58
REAL GAS UDF brian FLUENT 6 September 11, 2006 09:23
