Source terms in equations
Old   November 25, 2009, 08:23
Default Source terms in equations
Kapa Lilla
klilla is on a distinguished road
Dear All,
I try to add source terms in all the equations in coodles. When I add one to the density - so to the continuity equation - I found a rather strange behaviour. I printed out the magnitude of my source term from the function it calculates and from the solver itself (like rhoEqn.source()). Good news, they coincide. On the other hand:
diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0
It seems that the sources computed and assigned, but during the iterations they are not considered.
Can anyone help me on this issue?
Thanks,
Lilla
klilla is offline   Reply With Quote
Old   November 25, 2009, 08:35
niklas's Avatar
Niklas Nordin
niklas will become famous soon enoughniklas will become famous soon enough
If you're adding a source term to the continuity equations dont forget the addition to the PISO loop.
niklas is offline   Reply With Quote
Old   November 25, 2009, 08:39
Kapa Lilla
I did modify it as well. Unfortunatelly.
Old   November 26, 2009, 06:40
Kapa Lilla
I've performed an other test as well. Now with the original OF solver, so without source terms. It is a cavity flow. In fact the simulation is running, and the results seems meaningful. But I still have that funny line:
Have anyone idea why is it like that?
Thanks,
Lilla
Old   November 26, 2009, 06:56
niklas's Avatar
Niklas Nordin
because your matrix is purely diagonal.
fvm::ddt(rho) + fvc::div(phi) = S
produces a matrix-vector system like A*rho = H
and if A dont have any offdiagonal elements you can solve for rho exactly in 1 iteration.
Using source terms jsm Main CFD Forum 4 August 20, 2009 07:44
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 20:08
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 02:24
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
UDF Scalar Code: HT 1 Greg Perkins FLUENT 8 October 20, 2000 13:40
