Scott
Rep Power: 16 ![]() |
Hi All, this is just a simple question. I'm curious if anyone has run the throttle tutorial in the multiphase folder? I was curious how long it should take. I'm not really concerned here since I know CFD can take a while, just want to know what to expect The cavity tutorial took all of about 3 seconds and the throttle tutorial has been running all night (8 hours) so I'm not sure if it just takes a long time or if there could be a tolerance issue and its in limbo.
My machine has a dual Xeon Quad Core (8 cores) running at 3.2GHz, 8GB RAM, and Gentoo Linux. Thanks Scott |
Scott
Ok, It took about 60 hours to complete the simulation. Now I have a bunch of data and I'm not sure how to post process it. when I execute
"paraFoam -case procesor1" (0,2,3 are also options) ParaView opens and asks me to select a reader. I have tried every reader and none of them work. Can someone tell me what I should use? thanks Scott |
varun
Rep Power: 17 ![]() |
hi,
try to reconstruct your results with 'reconstructPar' . Next, convert your results to VTK format with 'foamToVTK'. Next, run paraFoam in your case directory, open the VTK folder and load your solution files. bye! P.S: Just ignore the reader error. |
A. Bernath
Rep Power: 15 ![]() |
Did your simulation converge?
As you can see in the attached picture, my residuals aren't that good and it doesn't look like this could change until the time hits the 1e-04 which is specified as the simulation end @default. Did you run the simulation further or also until 1e-04 s? Did you change anything else like the fvSolution for example? Thanks, Alex |
Tutorial for subcooled nucleate boiling | Asghari | FLUENT | 42 | December 10, 2018 11:42 |
Problem on Fluent Tutorial: Horizontal Film Boilig | Feng | FLUENT | 2 | April 13, 2013 05:34 |
STAR-CD Tutorial | shekhar aryal | STAR-CD | 4 | March 22, 2010 03:25 |
CFD-ACE Tutorial for Serpentine Fuel cell Channel | Taqi | Main CFD Forum | 0 | April 13, 2008 13:12 |
Rotor/stator tutorial, and how to... | gilberto | CFX | 5 | January 21, 2002 09:41 |
