writing modified U, but U was not change at all ?
Old   November 17, 2009, 23:37
Default writing modified U, but U file was not changed ?
Jiang
panda60 is on a distinguished road
Dear all:
I want to use U inflow profile, so I write a utility. First time it is victory. But when I run another case, U was not changed at all.
Although the screen has display that: writing modified U
End
But U acctually was not modified. I don't khow why. Because some other case has victory, why this case was not change.
How can I do this ?
Thank you very much.
This is my U file:
FoamFile
version 2.0;
format ascii;
class volVectorField;
location "0";
object U;
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0.1 0 0);
boundaryField
GAS_INLET
type fixedValue;
value uniform (0 1.8 0);
INLET
type fixedValue;
value uniform (1 0 0);
OUTLET
type zeroGradient;
SYM_LEFT
type symmetryPlane;
SYM_RIGHT
type symmetryPlane;
SYM_TOP
type symmetryPlane;
GROUND
type fixedValue;
value uniform (0 0 0);
BUILDING
type fixedValue;
This my code:
#include "fvCFD.H"
#include "OSspecific.H"
#include "fixedValueFvPatchFields.H"
int main(int argc, char *argv[])
# include "setRootCase.H"
# include "createTime.H"
# include "createMesh.H"
# include "createFields.H"
volVectorField::GeometricBoundaryField& Upatches = U.boundaryField();
forAll(Upatches, patchI)
if
(typeid(Upatches[patchI]) == typeid(fixedValueFvPatchVectorField))
(mesh.boundaryMesh()[patchI].name() == "INLET")
fixedValueFvPatchVectorField& Upatch =
refCast<fixedValueFvPatchVectorField>(Upatches[patchI]);
const vectorField& faceCentres =
mesh.Cf().boundaryField()[patchI];
forAll(faceCentres, facei)
scalar y = faceCentres[facei].y();
scalar Ux= 32.4*y+1.6;
scalar Uy=0.0;
scalar Uz=0.0;
Upatch[facei] = vector(Ux,Uy,Uz);
Info<< "Writing modified field U\n" << endl;
U.write();
Info<< "End\n" << endl;
return 0;
I have checked, if condition was not satisfied, so circle was not going on ,
I don't khow why "if( )" is not satisfied.
panda60 is offline   Reply With Quote
Old   November 18, 2009, 02:37
Kathrin Kissling
kathrin_kissling is on a distinguished road
Hi Panda,
you need to go U[patchI] == vector(Ux, Uy, Uz).
In any other way the boundary conditions don't get overwritten.
== forces the field to be overwritten.
This has something to do with the inhereitance of the operators for the fixedValue boundary condition = does nothing, so you need == which actually overwrites.
Hope this helps
Best
Kathrin
kathrin_kissling is offline   Reply With Quote
Old   November 18, 2009, 03:30
Jiang
Originally Posted by kathrin_kissling View Post
Hi Panda,
Hope this helps
Best
Kathrin
Dear Kathrin
the code internal of if() is not going on. Because I have checked that"(mesh.boundaryMesh()[patchI].name() == "INLET") " is not satisfied.
If it is because my grid have problem.
Solid/liquid phase change fabian_roesler OpenFOAM 10 December 24, 2012 07:37
Topo change doum OpenFOAM Running, Solving & CFD 0 June 22, 2007 17:26
Writing UDF for Unsteady Temperature change ? Baggi FLUENT 0 April 12, 2006 18:27
no enthalpy change across the momentum source Atit Koonsrisuk CFX 2 December 19, 2005 03:33
Multicomponent fluid Andrea CFX 2 October 11, 2004 06:12
