ata kamyabi
Rep Power: 18 ![]() |
Hi Foamers
I have a problem. I have a vessel that it's wall is rotating but I don't know how I could imply rotating wall velocity in OpenFOAM. Can any one help me? Thanks allot Ata |
Dear Ata,
I am not a coder, but do know of a boundary condition in src/finiteVolume/fields/fvPatchFields/derived/... known as "movingRotatingWallVelocity" which exists. I am not able to locate in my 1.5 version, but others are getting it to work. Best, Lori |
ata kamyabi
Hello lth
Thank you very much. That's true. I see. It is in OpenFoam-dev not in OpenFoam standard. Best regards Ata |
Anonymous
Rep Power: 17 ![]() |
There is a rotatingWallVelocity boundary condition for in the standard OpenFOAM 1.6 and 1.6.x releases. Apply it like so:
wall { type rotatingWallVelocity; origin (0 0 0); // origin of axis and the axis axis (0 1 0); // about which the wall will rotate omega 25; // m/s } For moving walls: wall { type movingWall; value uniform (1 0 0); // wall moving at 1m/s in x direction } Hope that helps. |
ata kamyabi
Hello Adriano
Thank you very much. I'll try it as soon as possible. Best regards. Ata |
Anonymous
Hi Ata,
Ignore the boundary condition for movingWall as it doesn't work. Instead, just set it to fixedValue and provide the correct velocity vector. Good luck! Cheers, adriano |
ata kamyabi
Hi Adriano
Thank you very much So what's rotatingWallVelocity boundary condition for? Best regards Ata |
[Commercial meshers] Fluent3DMeshToFoam | simvun | OpenFOAM Meshing & Mesh Conversion | 50 | January 19, 2020 15:33 |
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug | unoder | OpenFOAM Installation | 11 | January 30, 2008 20:30 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 19:13 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 05:12 |
applying boundary condition on rotating wall | Haris Maharana | Siemens | 2 | January 16, 2001 12:03 |
