anonymous
Rep Power: 16 ![]() |
Hi everyone,
recently i tried to use potentialfoam for getting a better initial-velocity field for further simulations. But i made the a strange, totally unphysical (or at least i think so ![]() ![]() First i thought that sth is wrong with my settings. But then i observed the same effect in the tutorial case pitzDaily. So with: outlet { type fixedValue; value uniform 0; } i obtain a max. velocity of about 27m/s ![]() But with: outlet { type fixedValue; value uniform 100000; } the max velocity is 1e6 m/s ![]() As far as i know the velocity in a potential flow shouldn't be affected by the reference value of the pressure. Has sb an idea what's wrong? Is it eventually a bug in potentialFoam (i briefly looked in the code, but everything look nice to me) ? If sb experienced the same effect, is there a better work around than just shifting the pressure to zero (and back..)? thanks for your answers |
Hello. I've tried something similar but I was looking for the U field. Have you used into an airfoil too?
Regards |
What are your inlet boundary conditions? From the tutorials I think they're zeroGradient with an outlet boundary condition of 0. If I understand the problem, it's trying to have an initial pressure of 1e6 Pa at one end and 0 Pa at the other (the whole pressure is uniform 0 at t=0), which is understandably hard to solve. Do you know your inlet/outlet boundary conditions well? Can you try putting in those pressures and seeing how that works out? How about trying to have the whole pressure at something closer to 1e6?
Neumann pressure BC and velocity field | Antech | Main CFD Forum | 0 | April 25, 2006 02:15 |
Gas pressure question | Dan Moskal | Main CFD Forum | 0 | October 24, 2002 22:02 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 05:13 |
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) | HB &DS | CFX | 0 | January 9, 2000 13:19 |
Hydrostatic pressure in 2-phase flow modeling (long) | DS & HB | Main CFD Forum | 0 | January 8, 2000 15:00 |
