dimensioned volScalarField
Old   November 11, 2009, 12:54
Default dimensioned volScalarField
Emanuele Leoni
lions85 is on a distinguished road
I'm programming in OpenFoam and I have a problem.
I am using a chemistry solver for some simple burners simulation.
In the transport equation I need to put the reaction velocity with its unit measures (so it has to be dimensioned). my velocity is a volScalarField, and when I declare a volScalarField I use this way:
volScalarField RR_Fuel
IOobject
"RR_Fuel",
runTime.timeName(),
mesh,
IOobject::NO_READ,
IOobject::AUTO_WRITE
mesh,
dimensionedScalar("RRfuel", dimensionSet(1,-3,-1,0,0,0,0), 0)
Then in the program I initialize the field, but in this case when I do that the right hand side and the left hand side of the equation need to be dimensioned with the same units.
The problem is that I want to initialize the scalarfield with a undimensioned right hand side. If I do that in the declaration after dimensionSet where instead of 0 I put for example 5, it works, the RR_Fuel will be dimensioned and with the value 5. I want to do the same but not in the declaration, and this is impossible because when I run the program it stops for the inconsistency of the units.
I hope you can understand my question, I was nebulous but it's very difficult to speak in english about this staff.
Thank you for your help
bye
EManuele
lions85 is offline   Reply With Quote
Old   November 12, 2009, 03:41
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
You should be able to address (read/write) the dimensions and the values of the field separately. The doxygen docs
http://foam.sourceforge.net/doc/Doxy...onedField.html mention both a dimensions() method and a field() method. The latter is probably good starting place for solving your problem.
olesen is offline   Reply With Quote
How to create initiate a volScalarField p without reading from disk NO_READ does not seem to work dbxmcf OpenFOAM Running, Solving & CFD 14 March 25, 2022 07:08
Wall distance volScalarField r2d2 OpenFOAM Running, Solving & CFD 3 October 10, 2018 13:54
Definition of a linear function as volScalarField titio OpenFOAM Running, Solving & CFD 1 October 3, 2010 17:51
Is there a way to change the name a volScalarField liu OpenFOAM Running, Solving & CFD 2 October 18, 2007 18:49
Problems with volScalarField niklas OpenFOAM Running, Solving & CFD 2 November 28, 2005 17:05
