write wallGradU to one file
Old   November 8, 2009, 02:44
Default write wallGradU to one file
Sven Winkler
sven is on a distinguished road
if I execute wallGradU as a postprocessing tool, the wall Gradient is written for every timestep in the appropriate time folder. Is there any way, that I can get OpenFOAM to write the wall Gradient for every time step in only one file, that means I only want to have one single file which contains two columns, first column is the time and second column the wallGradU! Does anyone know how to do this? Thanks a lot!
sven is offline   Reply With Quote
Old   March 19, 2011, 19:58
Default Did you find a way ?
ksv
ksv
ksv is on a distinguished road
Hi Sven,
With regard to your earlier post, have you found out a way to write all output files in a single folder. I am facing the same issuew now and hence seeking your suggestion.
Thanks
ksv
ksv is offline   Reply With Quote
Convection discretization schemes for LES sek OpenFOAM Running, Solving & CFD 38 July 31, 2017 15:30
[OpenFOAM] Paraview command not found hardy ParaView 7 September 18, 2008 05:59
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 15:00
Write .def file from command line Alejandro CFX 3 September 11, 2005 19:14
write plot3d file of CFX h6h6 CFX 0 December 2, 2003 03:00
