Mapfields with two different turbulence models |
November 4, 2009, 11:23 |
Rep Power: 17 |
Dear Foamers,
I've got two meshes (coarse/fine) and I use a different turbulence model for both of them. Basically, I was wondering if it was possible to use Mapfields in order to import results from coarse mesh as an initial condition for the fine mesh which uses another turbulence model. Thanks! |
November 16, 2009, 02:35 |
N/A
Rep Power: 17 |
The initial conditions on the turbulent variables do not matter a lot. As long the the velocity field is perturbed, turbulence will develop and you should be able to obtain statistics.
Discussion: Reason of Turbulence!! | Wen Long | Main CFD Forum | 3 | May 15, 2009 10:52 |
Turbulence Models and external flow. | Alan | FLUENT | 3 | November 22, 2005 05:46 |
How to set phase dependent turbulence models? | J.Yang | CFX | 2 | August 29, 2002 16:39 |
Why Turbulence models are not universal. | Senthil | Main CFD Forum | 4 | July 5, 2000 05:34 |
