how to make parallel running? decomposePar.
Old   October 28, 2009, 23:17
Default how to make parallel running? decomposePar.
Jiang
panda60 is on a distinguished road
Dear foamers,
I want to use parallel simulation, I followed the User Guide's 3.4.2, and copy a decomposeParDict to the system directory.
But when I run the command "decomposePar" in the case directory,
It displays that: command not found.
If OpenFOAM's parallel running needs to be set, How counld I set this step by step ? where I could find these setting reference ?
Thank you very much.
panda60 is offline   Reply With Quote
Old   October 29, 2009, 03:43
Christof Benz
chbenz is on a distinguished road
sounds like decomposePar isn't available. check with
which decomposePar
Somethink like this should be shown in the terminal
~/OpenFOAM/OpenFOAM-1.5-dev/applications/bin/linux64GccDPOpt/decomposePar
if not OpenFOAM isn't build complete.
Christof
chbenz is offline   Reply With Quote
Error while running in PARALLEL Ravi Duggirala FLUENT 4 August 3, 2010 11:01
Error when running in parallel vishwa OpenFOAM 1 October 23, 2009 09:42
error running parallel data write ak6g08 Fluent UDF and Scheme Programming 0 October 2, 2009 12:40
Getting error while running on parallel Mode velan OpenFOAM Running, Solving & CFD 8 May 10, 2009 04:26
Running interDyMFoam in parallel sega OpenFOAM Running, Solving & CFD 1 March 12, 2009 06:54
