yPlus query
Old   October 28, 2009, 06:02
Default yPlus query
varun
vw.cfd is on a distinguished road
I have a basic query regarding the yPlus value and the associated(or appropriate) turbulence model, I wish to use the k-omega+SST model. What should be the appropriate yPlus value for good functioning of this model on openFoam. I have read in several threads that for K-epsilon model the yPlus should be in the log layer (y+>10). Is it the same case with komega+SST or should it be in the laminar sub-layer?
thnX!!
vw.cfd is offline   Reply With Quote
Old   October 28, 2009, 08:06
Simon Lapointe
Simon Lapointe is on a distinguished road
The kOmegaSST model in OpenFOAM uses wall functions and thus requires a high y+ value. However, in 1.5-dev there is a kOmegaSST_LowRe which, I think, can resolve the near-wall region and should be used with a small y+.
Hope this helps
Simon Lapointe is offline   Reply With Quote
Old   October 28, 2009, 10:20
varun
Hi Simon,
I will try this out.
ThanX!!
Old   October 29, 2009, 08:53
varun
Hi Simon,
I tried your suggestion on openfoam 1.5-dev,
I obtain this error message:
Unknown RASModel type kOmegaSST_LowRe
Valid RASModel types are :
15
NonlinearKEShih
kEpsilon
realizableKE
LienCubicKELowRe
LienLeschzinerLowRe
LaunderSharmaKE
laminar
SpalartAllmaras
LienCubicKE
LamBremhorstKE
RNGkEpsilon
LRR
QZeta
LaunderGibsonRSTM
kOmegaSST
Which turbulence model did you mean exactly?
ThnX!!
Old   October 29, 2009, 10:24
Simon Lapointe
Hi varun,
The kOmegaSST_LowRe model has been added recently to OpenFOAM-1.5-dev so you need to update your OpenFOAM (or download the model source code) to get it.
Old   February 18, 2010, 10:08
Claus Meister
idrama is on a distinguished road
Hey, foamers!
I am already using OpenFOAM 1.6. The mentioned mole does not exist.
Cheers
idrama is offline   Reply With Quote
Old   February 22, 2010, 06:44
MadsR's Avatar
Mads Reck
MadsR is on a distinguished road
bump - any new info on this?
Online free airfoil-mesher for OpenFOAM here
MadsR is offline   Reply With Quote
Old   February 23, 2010, 04:25
Tammo Wenterodt
wenterodt is on a distinguished road
The source of the kOmegaSST_lowRe model can be downloaded here:
http://openfoam-extend.svn.sourcefor.../?pathrev=1415
it does not directly compile with 1.6, though only little changes neccessary:
at kOmegaSST_LowRe/kOmegaSST_LowRe.C line 171 add
kappa_
         dimensioned<scalar>::lookupOrAddToDict
           "kappa",
            coeffDict_,
           0.41
and at line 313 add
kappa_.readIfPresent(coeffDict_);
in kOmegaSST_LowRe/kOmegaSST_LowRe.H add at line 131
dimensionedScalar kappa_;
I have used it in 1.6 a lot so far in 1d and 2d problems obtaining very good results (pipes, channels, plate heat exchangers, tube bundle heat exchangers).
BUT I face major problems in 3d geometries, where the model results in distinct pressure fronts in the domain, which then make the calculation crash.
I'd be glad for any ideas on that!
//Tammo
wenterodt is offline   Reply With Quote
Old   February 23, 2010, 07:15
Claus Meister
Hello wenterodt,
could you please post the procedure to install it in OpenFOAM-1.6?
Cheers,
Claus
Old   February 23, 2010, 08:19
Tammo Wenterodt
Basically just write Make/files and Make/options, compile (wmake libso) and add a line to the controlDict
The procedure is pretty much the same as described here:
http://www.tfd.chalmers.se/~hani/kurser/OS_CFD_2008/implementTurbulenceModel.pdf
// Tammo
Old   March 3, 2010, 16:12
Default Wall function on LowRe model
  #11
Pekka is on a distinguished road
Hello Tammo,
have you any experience in nut boundary conditions on kOmegaSST_LowRe RAS model. It is zeroGradient or some nut wall function?
Thanks.
Pekka is offline   Reply With Quote
Old   March 10, 2010, 15:39
Claus Meister
Hey Foamers!
I do not understand the purpose of yPlus. I found that tool yPlusRAS and executed. I got this values, but what should I do with these? I have been watching in many books.
Cheers,
Claus
turbulence model, yplus
How to choose the YPLUS value in two-phase flows? Niewlande FLUENT 3 December 7, 2015 16:43
Who stole my Yplus? Chebeba CFX 4 March 23, 2006 05:18
YPlus value -- CFX 5.7 NeedHelp CFX 3 December 7, 2004 21:46
X-Y plot of Yplus in Fluent 5.3 Luo FLUENT 24 April 11, 2000 07:07
heat transfer coefficients with "bad" yplus Andrew Main CFD Forum 4 April 8, 1999 05:43
