Explicit Source Term
Old   October 23, 2009, 11:22
Default Explicit Source Term
Primoz Ternik
ternik is on a distinguished road
hi,
I would like to model fluid flow with additional EXPLICIT SOURCE TERM appearing in a momentum equation - here I would like to be able to define this source term as a function of time ("switch it on and of") as well as geometry (small region inside the fluid domain).Can this can be done by timeActivatedExplicitSource.C? If so, can anyone explain me "how and what"!
I am still (satisfied) with OF-1.5!
Thanks,
Primoz.
ternik is offline   Reply With Quote
Old   October 25, 2009, 21:32
Kurt Pudniks
skinduptruk is on a distinguished road
i'm only new but i think...
groovyBC has stuff being turned on and off with time. i saw a wiki page.
skinduptruk is offline   Reply With Quote
Old   October 27, 2009, 14:12
Assistant Moderator
Bernhard Gschaider
Yeah. But it only does boundary conditions. No source terms.
Bernhard
Old   January 13, 2011, 16:50
Robin Gilbert
robingilbert is on a distinguished road
any ideas how to implement time varying source terms??
robingilbert is offline   Reply With Quote
Old   January 13, 2011, 17:05
Mirko Vukovic
mirko is on a distinguished road
There was a thread started in june/july 2010 by Maddalena about adding a source term to the temperature equation.
She modified the solver by adding a source term. It worked well for a single region, but not for multiple regions. Still, it might be of some help.
Mirko
mirko is offline   Reply With Quote
Old   January 13, 2011, 17:08
Assistant Moderator
Bernhard Gschaider
You'll have to add it to the the relevant transport equation. Just add a field and you're done. The question is how you get the values into the field. For that there are several optinos:
- Programing by hand
- Using the scalarTimeActivatedExplicitSourceList that comes with OF (I guess. Havn't worked with that)
- Swak4Foam has the possibility to have arbitrary source terms based on an expression. For a discussion see http://www.cfd-online.com/Forums/ope...ak4foam-4.html
Bernhard
momentum source term zwdi FLUENT 14 June 27, 2017 16:40
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 02:24
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
UDF Scalar Code: HT 1 Greg Perkins FLUENT 8 October 20, 2000 13:40
UDFs for Scalar Eqn - Fluid/Solid HT Greg Perkins FLUENT 0 October 14, 2000 00:03
