October 21, 2009, 06:21 |
Explosion inside a cube - blockMesh
Dennis Rown
Rep Power: 17 |
Hello!
I want to model a a simple cube and simulate an explosion inside that cube. I thought of another small cube that has high pressure in it, which is ater a while released into the big cube. Since I am very new with blockMesh, for modelling that in blockMesh I have a question. How many blocks do I have to create at least? Are two blocks (big cube, small cube) enough or won't blockMesh work that way and I will have to create tons of blocks? |
October 21, 2009, 08:38 |
Dennis Rown
Rep Power: 17 |
I found out that I don't have to create an additional block at all for the case. Just one block is enough.
January 16, 2013, 14:00 |
angel
Rep Power: 17 |
March 6, 2013, 04:59 |
Charlie Tan
Rep Power: 15 |
Hello!
Which solver are you using to simulate a TNT Explosion on OpenFoam? Thank you so much! |
Gambit help: Cube inside cube | Jack Martinez | FLUENT | 13 | August 11, 2010 07:29 |
[blockMesh] error Meshing a 3D cube geometry with blockMesh | GodOfLove | OpenFOAM Meshing & Mesh Conversion | 5 | July 14, 2009 16:30 |
A tilted 3D cube inside a wind tunnel | jam | OpenFOAM Running, Solving & CFD | 5 | February 29, 2008 13:21 |
[blockMesh] Surface mounted cube blockmesh example | braennstroem | OpenFOAM Meshing & Mesh Conversion | 0 | December 9, 2005 07:41 |
meshing F1 front wing | Steve | FLUENT | 0 | April 17, 2003 13:37 |
