October 20, 2009, 15:57 |
OpenFOAM-1.6 on Mac OS X 10.6.1
Elvis Dowson
Rep Power: 17 |
I am trying to build OpenFOAM-1.6 from the sources tar-ball for Mac OS X 10.6.1. I have applied the v2 patches for Mac OS X, but that didn't seems to work. Could someone please send me a link to the latest version of patches for OpenFOAM-1.6 for Mac OS X 10.6? Can I use the system supplied gcc and g++ applications? Compilation fails for both OpenFOAM and ThirdParty libs, and it complains about not being able to find some standard c++ headers, etc. Which compiler should I use? Can't it work with what is supplied with Snow Leopard by default? Best regards, Elvis Dowson |
October 21, 2009, 14:23 |
#2 | |||
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
https://openfoam-extend.svn.sourcefo...r/patchMacOSX/ but there may be others on the board Quote:
Compiler: OF 1.6 needs a 4.3-compiler. 4.2 won't work on some source files. 4.4 has problems with the sources too (solvable) but some parts of the Paraview-CVS need the system-4.2-compiler. So no easy answer here Bernhard |
October 21, 2009, 15:24 |
Elvis Dowson
Rep Power: 17 |
Hi Bernhard,
I just managed to configure and build qt-4.5.3 from the latest qt repository, to try to build paraview for 64-bits. I have ensured that qt-4.5.3 is built for 64-bits by using the cocoa and x86_64 options. ./configure -platform macx-g++ -cocoa -arch x86_64 -no-xmlpatterns -no-phonon -prefix /Developer/Applications/Qt-4.5 Where should I get the cvs version of paraview? Should I download it from the kitware site? Best regards, Elvis |
October 21, 2009, 15:26 |
#4 | |
Elvis Dowson
Rep Power: 17 |
So, I hope that takes care of my compiler issue? :-) Best regards, Elvis |
October 21, 2009, 15:44 |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
October 21, 2009, 15:50 |
#6 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
If someone finds a more elegant way: let me know Bernhard |
October 21, 2009, 16:45 |
Elvis Dowson
Rep Power: 17 |
Hi Bernhard,
If I were to download OpenFOAM-1.6.x from the git repository, how do I go about applying the patch that you have created? The current patch fails, and I was wondering if I will have to manually apply the patch and regenerate a new patch file using git format-patch command. Also, for the git repository, I did not find any info on list of branches or tags for OpenFOAM, do some branches or tags exist? Best regards, Elvis |
install OpenFoam 1.6 by building source: how? | niudie | OpenFOAM Installation | 13 | April 26, 2011 01:48 |
install openfoam 1.6 on opensuse 11.0 | andresbh | OpenFOAM Installation | 8 | September 30, 2009 01:48 |
OpenFOAM 1.6 CreatePatch Problem | TarifaPirata | OpenFOAM Bugs | 1 | September 10, 2009 05:35 |
OpenFOAM 1.6 package - CentOS 5.3 x86_64 | linnemann | OpenFOAM Installation | 36 | September 2, 2009 13:46 |
OpenFOAM Version 1.6 Released | opencfd | OpenFOAM Announcements from ESI-OpenCFD | 0 | July 27, 2009 18:55 |
