October 14, 2009, 11:16 |
Residual values
I am a new user of openfoam. Does anyone of you know how to write the values of the residuals per iteration in a steady or unsteady (inner iterations) case? I don't know how to obtain this values to be able to plot the convergence history as you can do in fluent, starccm+,.....In addition, how to specify the number of iterations instead of the tolerance for the solution procedure.
Thanks in advance |
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 16:33 |
Low Mach number Compressible jet flow using LES | ankgupta8um | OpenFOAM Running, Solving & CFD | 7 | January 15, 2011 14:38 |
Computational time | sunnysun | OpenFOAM Running, Solving & CFD | 5 | March 16, 2009 04:32 |
Differences between serial and parallel runs | carsten | OpenFOAM Bugs | 11 | September 12, 2008 12:16 |
Convergence moving mesh | lr103476 | OpenFOAM Running, Solving & CFD | 30 | November 19, 2007 15:09 |
