October 10, 2009, 05:49 |
rhoSimpleFoam & buoyantFoam
toto
Rep Power: 17 |
I tried to simulate using rhoSimpleFoam and buoyantSimpleFoam, but I became following problems: 1. The Pressure Solver needs 1000 Iteration per Timestep 2. I canīt find the thermoType below under thermophysicalpropeties thermoType hThermo<pureMixture<constTransport<specieThermo<hC onstThermo<perfectGas>>>>>; - could someone send me a case simulated using rho- or buoyantSimpleFoam ? - I would also like to know how to set alpha, mut, p, T under "0-Directory" Thank you in advance (It is very important please!) |
October 11, 2009, 08:45 |
Tian
Rep Power: 17 |
Hi Ronaldo,
maybe my case help you a little bit. It is for OpenFOAM Version 1.5-dev (bouyantSimpleFoam). It is a small room with 3 inlets and 3 outlets. Your problem looks like a pressure boundary mistakes (1000 iterations). http://rapidshare.com/files/291528070/raum.tgz.html Bye Tian |
TRANSONIC FLOW in RHOSIMPLEFOAM | dinonettis | OpenFOAM Running, Solving & CFD | 10 | September 13, 2018 11:22 |
transient buoyantFoam including radiation? | thomasduerr | OpenFOAM | 0 | June 5, 2009 08:04 |
RhoSimpleFoam | jphandrigan | OpenFOAM Running, Solving & CFD | 18 | March 29, 2009 12:05 |
RhoSimpleFoam FoamX | spv24 | OpenFOAM Running, Solving & CFD | 1 | July 21, 2008 11:29 |
Stability startup problems with rhoSimpleFoam | olesen | OpenFOAM Running, Solving & CFD | 1 | July 18, 2006 09:09 |
