Philosophy of implicit solution of different regions
Old   October 5, 2009, 11:53
Default Philosophy of implicit solution of different regions
Louis le Grange
Louis Le Grange is on a distinguished road
Hi
I have a few questions in this regard;
1) What happened to the coupledMatrix source directory from previous versions to 1.6? Or was it only available in previous -dev releases? Will the coupledMatrices appear again in a 1.6-dev?
2) It seems to me that the philosophy in OpenFOAM regarding say the solution of the energy equation in different materials is to treat each material separately as far as possible and then also solve it seperately as in a parallel case - with updating of the material interface fluxes or boundary conditions between iterations. I can see some advantages in this regarding the object orientated aproach. Am I right in my perception?
3) Is there perhaps a study available on the considerations on whether to solve different regions implicitly in 1 matrix or seperately sequential or parallel for that matter, ito convergence, speed, convenience, etc?
4) I have experience of certain solid-fluid problems that needs to be very closely coupled in terms of temperature such as counter-current heat exchangers. In such cases it is virtually impossible to get convergence (even given an implict temperature 1-matrix solution method) using standard iterative numerical solution methods such as a bicg-method - special measures are needed such as direct solution methods. If my understanding in 2) is correct - would the seperate solution of the different materials not be even further detremental to the success of solutions to the problem stated in 4)?
Thanks in advance,
Louis
Louis Le Grange is offline   Reply With Quote
cht, coupled, multi regions
Solution technique/ Mesh type/ Cell limit/ Multi-zone regions in CFX zandi CFX 5 April 10, 2009 02:06
Solution technique/ Mesh type/ Cell limit/ Multi-zone regions in FLUENT zandi FLUENT 0 April 6, 2009 05:04
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 03:58
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 19:07
Wall functions Abhijit Tilak Main CFD Forum 6 February 5, 1999 02:16
