Stream Function - How to Visualise It?
Old   October 2, 2009, 12:19
Default Stream Function - How to Visualise It?
Primoz Ternik
ternik is on a distinguished road
I am running tutorial case (driven cavity) just to check "if & how" works the streamFunction utility... I am getting results (streamFunction) for each time step, but unfortunately I can not visualise it with the ParaView! Can you please give some hints on this...
I am also wondering if it is possible to plot streamFunction with the sample utility? If so, I am looking forward for a "cook-book" on this as well!
Thanks in advance,
Primoz,
P.S.: I am using OF-1.5...
ternik is offline   Reply With Quote
Old   October 3, 2009, 07:07
Hrvoje Jasak
You need to visualise iso-lines of stream function on a cut through the cavity.
This will give you the stream tubes. Please note: stream function is only defined in 2-D.
Enjoy,
Hrv
Hrvoje Jasak
Old   October 3, 2009, 07:55
Default Hi Hrvoje,
Primoz Ternik
thanks for your reply. Unfortunately, results for the stream function (as calculated with a "streamFunction" utility) are not loaded when running the Paraview - if I am not mistaken, I should be able to see & load results under the Point Field Status within the ParaView...
Any further suggestions are more than welcome and highly appreciated!
Wish you a nice day,
Primoz.
streamfunction
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 10:31
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 15:11
Error with Wmake skabilan OpenFOAM Installation 3 July 28, 2009 01:35
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 21:50
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 15:00
