Unable to run OF in parallel on a multiple-node cluster
Old   September 23, 2009, 13:09
Default Unable to run OF in parallel on a multiple-node cluster
S Kumar
quartzian is on a distinguished road
I have been trying to run OF in parallel on our linux cluster. I am using the decomposeParDict. Our cluster has several nodes of 8 processors each, and while I am able to run OF in parallel on a single node (up to 8 processors), what happens when I try to run it on more than 1 node is that all the jobs still end up running on just one node. So, for example, when I submit the job to a queue (after using decomposePar) for 16 processors on 2 nodes, all 16 jobs run on a single node.
All the nodes are nfs mounted with passwordless access.
I have tried both using the roots field and not using it (even though the filesystem is common), but it hasn't made a difference.
Please help.
Thanks,
Kumar
quartzian is offline   Reply With Quote
Old   September 23, 2009, 17:21
akidess's Avatar
Anton Kidess
How do you execute OpenFOAM?
If you use PBS, your submission script should look like:
#PBS -l nodes=2:ppn=8,walltime=24:00:00
cd $PBS_O_WORKDIR
$MPI_ARCH_PATH/bin/mpirun -np $NPROCS --hostfile $PBS_NODEFILE $SOLVER -parallel
You can also try to use the -nooversubscribe flag for MPI.
Old   September 24, 2009, 04:32
S Kumar
I figured out the problem. I was not using the -hostfile option. I was using the -np $NPROCS option, and without the -hostfile option mpirun was only picking up the first node specified in the hostfile.
Now the parallel run works properly.
Thanks for the response!
Kumar
Old   November 24, 2009, 14:37
xinguang cui
flying is on a distinguished road
Hey quartzian and akidess:
I also have met similiar problem, please give me some advice. Thanks a lot.
There is gcc4.4.1 and openmpi 1.3.3 in the cluster.
I should use all of the complier in the cluster. I am not allowed to use any complier in the thirdparty when the code is run in multi-nodes.
So, I need to compile the openfoam with the compile in cluster.
I have to set up in my home directory by myself.
First question, Are gcc 4.4.1 and openmpi 1.3.3 enough for compile openfoam 1.5?
Second question, if it is enough , how do I do it?
I have changed the complier option and mpi setting up option. As follows
# WM_COMPILER_INST = OpenFOAM | System
WM_COMPILER_INST=OpenFOAM (Orginal)
WM_COMPILER_INST=System (changed)
case "$WM_MPLIB" in
OPENMPI)
mpi_version=openmpi-1.2.6
# export MPI_HOME=$WM_THIRD_PARTY_DIR/$mpi_version
export MPI_HOME=$WM_THIRD_PARTY_DIR/$mpi_version (orginal)
# export MPI_ARCH_PATH=$MPI_HOME/platforms/$WM_OPTIONS (orginal
export MPI_ARCH_PATH=/opt/openmpi/1.3.3/gcc-4.4.1 (changed)
It could compile. But there is some error information as follows:
Note: ignore spurious warnings about missing mpicxx.h headers
+ wmake libso mpi
Making dependency list for source file OPwrite.C
could not open file ompi/mpi/cxx/pmpicxx.h for source file OPwrite.C
could not open file ompi/mpi/cxx/constants.h for source file OPwrite.C
could not open file ompi/mpi/cxx/functions.h for source file OPwrite.C
could not open file ompi/mpi/cxx/datatype.h for source file OPwrite.C
could not open file ompi/mpi/cxx/exception.h for source file Opwrite.C
Who would like to give me some idea about it?
flying is offline   Reply With Quote
Cant run in parallel on two nodes using OpenMPI CHristofer Main CFD Forum 0 October 26, 2007 10:54
Run in parallel a 2mesh case cosimobianchini OpenFOAM Running, Solving & CFD 2 January 11, 2007 07:33
Serial run OK parallel one fails r2d2 OpenFOAM Running, Solving & CFD 2 November 16, 2005 13:44
How to run parallel in ICEM_CFD? Kiddo Main CFD Forum 2 January 24, 2005 09:53
DHCP, Cluster computing, Parallel processing ? Jihwan Siemens 1 January 2, 2005 18:32
