How to use rotatingWallVelocity boundary condition
Like Tree4Likes
Old   June 16, 2012, 09:34
calim_cfd's Avatar
mauricio
calim_cfd is on a distinguished road
hi!
have you set the reference axis and origin point properly? i mean.. if ur cylinder is to rotate around its axial axis, this axis should be the reference one and the origin any point on the center of the cylinder base..
if you have those properlly then i guess we'd have to see your case.. post the 0/ folder files plus the constant ones w/o the mesh, if its too big
Best Regards
/calim
"Elune will grant us the strength"
calim_cfd is offline   Reply With Quote
Old   June 16, 2012, 10:28
Bhupesh
bhups45 is on a distinguished road
hi...
Thanx for ur rply...
Now i got my simulation correctly using you code only...
I had not deleted the "value" field of "fixedValue" condition..
bhups45 is offline   Reply With Quote
Old   October 4, 2012, 19:30
Unhappy
  #23
ali jafari
ali jafari is on a distinguished road
Originally Posted by gpextra View Post
Dear colleagues,
I am making use of this post to show you a similar problem I have had using rotating walls with OpenFoam. I am a beginner (in OpenFoam) and this is the case:
It is a lid-driven cavity problem where the lid is not flat, but a rotating cylinder. The solver was icoFoam from OpenFoam 2.0.0. Conceptually this is exactly the same old 2D lid-driven cavity, but with this slightly different geometry. The internal flow details are unimportant and I will focus only on the wall velocity. This is part of the mesh dictionary to illustrate the very simple geometry:
convertToMeters 0.001;
vertices
(0 0 0) // 0
(1 0 0) // 1
(1 1 0) // 2
(0 1 0) // 3
(0 0 1) // 4
(1 0 1) // 5
(1 1 1) // 6
(0 1 1) // 7
blocks
hex (0 1 2 3 4 5 6 7) (20 20 1) simpleGrading (1 1 1)
edges
arc 3 2 (0.5 1.5 0)
arc 6 7 (0.5 1.5 1)
The velocity boundary condition for the (rotating) lid is is specified as
bump
type rotatingWallVelocity;
origin (0.5 1 0);
axis (0 0 1);
omega 0.001; // a rather small value!
Well, I would expect that the wall absolute velocity was constant, and the x and y-velocities were of sin or cos shaped. But no! The wall velocity profile, shown in the attached figure, has a misbehaving y-velocity component with one full period of a sine (the x-velocity component is not that bad).
In fact this is a simplified version of my real problem, where I identified this weird behavior, just to illustrate the essence of the problem with rotating walls. I have also attached a zipped file with all the other relevant files, in case someone wants to run the case.
I hope someone can help me with this weirs wall velocity profile.
Regrads,
G.Paulo.
Hi
I used your case but this error appeared OF 1.5 dev)
Cannot find 'value' entry on patch bump of field U in file "/home/ali/OpenFOAM/ali-1.5-dev/run/rotatingwall/0/U"
which is required to set the values of the generic patch field.
(Actual type rotatingWallVelocity)
Please add the 'value' entry to the write function of the user-defined boundary-condition
or link the boundary-condition into libfoamUtil.so
file: /home/ali/OpenFOAM/ali-1.5-dev/run/rotatingwall/0/U::bump from line 31 to line 34.
From function genericFvPatchField<Type>::genericFvPatchField(con st fvPatch&, const Field<Type>&, const dictionary&)
in file fields/fvPatchFields/basic/generic/genericFvPatchField.C at line 72.
FOAM exiting
also this error occur on other case that include rotatingwallvelocity !!
my OF has a problem ?!
Regrads
ali jafari is offline   Reply With Quote
Old   March 25, 2013, 21:59
Albert Tong
tfuwa is on a distinguished road
Hi Foamers,
Hope this thread is still active. I would like to set a time-dependent rotating speed, for instance,
t<10, omega=5;
t>10, omega=0;
Is it possible to do this with rotatingWallVelocity? Many thanks.
Regards,
Albert
tfuwa is offline   Reply With Quote
Old   March 26, 2013, 18:03
calim_cfd's Avatar
mauricio
Originally Posted by tfuwa View Post
Hi Foamers,
t<10, omega=5;
t>10, omega=0;
Regards,
Albert
hi
im confident u can do that with SwAK4Foam http://openfoamwiki.net/index.php/Contrib/swak4Foam
but check the new type of bc which allows for time dependent BCs.. u might have to insert a table and ur BC should like this
uniformValue     table
    (0   0.0)
    (5  10.0)
first colum time and the other the variable of the bc... check the *.c and *.h file you should find something there .. also read this release http://www.openfoam.org/version2.1.0...conditions.php
i guess u dont need ti use swak4foam
good luck!
im not on my Foam desktop but check for a type of BC which is
Best Regards
/calim
Old   February 7, 2018, 19:49
Default Regarding the Reynold's number in Rotational wall velocity
  #26
Anand
Anand895130 is on a distinguished road
Hello Everyone
I'm using this code for running my Rotating wall,
bump
origin (958.85 1755.17 0);
axis (0 0 1);
omega constant 230.3834; //rad per sec using 13200 deg/s=2200 rpm value;
In this what will be the reynold's number. and how to change the reynold's number if I want to ?
Thanks in Advance
Any reply will be helpful
Anand895130 is offline   Reply With Quote
Old   February 7, 2018, 19:53
  #27
Anand
Hello Everyone
bump
axis (0 0 1);
Thanks in Advance
Boundary Conditions Thomas P. Abraham Main CFD Forum 20 July 7, 2013 06:05
Axis Boundary Condition..what is it? CFDtoy FLUENT 6 February 13, 2007 06:51
How to set boundary condition in Fluent for the fo Peiyong FLUENT 1 November 10, 2006 12:44
1 and 2 Order Boundary condition at the same place CFD_Flo Main CFD Forum 4 July 11, 2005 12:57
How to resolve boundary condition problem? sam FLUENT 2 July 20, 2003 03:19
