August 28, 2009, 03:59 |
Inlet varying with time
jhegar
Rep Power: 17 |
hello everybody!!
I have to simulate a pipe in which the water flow input depends on the time. What I´m trying, is to set a velocity in the inlet path that changes with the time (my problem is inkompressible). But I have no idea how I can do this. And by the moment I have not found any usefull information that could help me with this task. Could any one there help me with this problem?? Thank´s for your time and help. |
August 28, 2009, 04:25 |
Julien Schaguene
Rep Power: 17 |
did you make a search on the forum? I think this topic had been discuss before. From what I read before, there are multiple solutions: - the one I'm using, modifying inlet velocity at each time step by adding a piece of code in the solver. - groovyBC should also give a solution - I also read about timeVaryingInlet but I never tried it. If you want some advices to "modify" the solver (in fact, just adding an include), you can mp me. regards, Julien |
August 31, 2009, 03:59 |
jhegar
Rep Power: 17 |
thank you very much. I will try with groovyBC, anyway I´ll ask you for some advices on modifying the solver, because I think that in some moment I will need to do it. Thank you very much for your help. Have a nice week. Jorge |
August 31, 2009, 04:50 |
Niklas Nordin
Rep Power: 29 |
Here's a bc I use for time-varying conditions.
bc_whatever { type timeVaryingFlowRateInletVelocity; fileName "inlet1.dat"; flowRate 0.1944; outOfBounds repeat; value uniform ( 0 0 0 ); } the inlet1.dat file is placed in the case directory and for me it looks like this ( (0 0) (13.89e-3 0.1944) (27.78e-3 0) (100.0e-3 0) ) this will produce a triangular inlet wave with 27.83 ms duration, every 100 ms. copy/paste from the bc-file found at src/finiteVolume/fields/fvPatchFields/derived/timeVaryingFlowRateInletVelocity Code:
Example of the boundary condition specification: @verbatim inlet { type timeVaryingFlowRateInletVelocity; flowRate 0.2; // Volumetric/mass flow rate [m3/s or kg/s] value uniform (0 0 0); // placeholder fileName "$FOAM_CASE/time-series"; outOfBounds repeat; // (error|warn|clamp|repeat) } @endverbatim Note - The value is positive inwards - may not work correctly for transonic inlets! - strange behaviour with potentialFoam since the U equation is not solved |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 05:36 |
time dependent inlet subroutine. HELP!!! | jimmer | Siemens | 4 | November 10, 2008 08:49 |
time varying inlet velocity | Zhe Liu | CFX | 0 | July 31, 2008 06:56 |
sinsoudial time varying BC | cfd-student | CFX | 4 | May 1, 2008 19:06 |
Time Varying Boundary Conditon | ashish | CFX | 3 | February 15, 2005 06:21 |
