openfoam 1.5-dev on opensuse10.3-64bit
Old   August 19, 2009, 16:51
Default openfoam 1.5-dev on opensuse10.3-64bit
Disabled
anon_c is on a distinguished road
this is the foamInstallTest what it gives out
(after tar -xfz Openfoam-1.5_dev
thirdparty _ general and gcc64 )
and then .bashrc editing and resource and that is the flouing error i get??
could any one help
Executing /home/ammar/OpenFOAM/OpenFOAM-1.5-dev/bin/foamInstallationTest:
Checking basic setup...
Shell: bash
Host: ifm-pc87
OS: Linux version 2.6.22.19-0.3-default
Checking main OpenFOAM env variables...
Environment_variable Set_to_file_or_directory Valid Crit
$WM_PROJECT_INST_DIR /home/ammar/OpenFOAM yes yes
$WM_PROJECT_USER_DIR /home/ammar/OpenFOAM/ammar-1.5-dev yes no
$WM_THIRD_PARTY_DIR /home/ammar/OpenFOAM/ThirdParty yes yes
Checking the OpenFOAM env variables set on the PATH...
Environment_variable Set_to_file_or_directory Valid Path Crit
$WM_PROJECT_DIR /home/ammar/OpenFOAM/OpenFOAM-1.5-dev yes yes yes
$FOAM_APPBIN ...dev/applications/bin/linux64GccDPOpt yes yes yes
$FOAM_USER_APPBIN ...dev/applications/bin/linux64GccDPOpt yes yes no
$WM_DIR ...mmar/OpenFOAM/OpenFOAM-1.5-dev/wmake yes yes yes
Checking the OpenFOAM env variables set on the LD_LIBRARY_PATH...
$FOAM_LIBBIN ...OpenFOAM-1.5-dev/lib/linux64GccDPOpt yes yes yes
$FOAM_USER_LIBBIN ...AM/ammar-1.5-dev/lib/linux64GccDPOpt yes yes no
$MPI_ARCH_PATH ...nmpi-1.2.6/platforms/linux64GccDPOpt yes yes yes
Third party software
Software Version Location
WARNING: gcc version does not match gcc supplied with this release of OpenFOAM
Supplied version: 4.3.1
User version : ../configure
4.2.1
Minimum required: 4.2.0
gcc ...figure
WARNING: Conflicting installations:
OpenFOAM settings : /bin/gcc
current path : /usr/bin/gcc
CRITICAL ERROR
gzip 1.3.12 /usr/bin/gzip
tar 1.17 /bin/tar
icoFoam
OpenFOAM settings : /home/ammar/OpenFOAM/OpenFOAM-1.5-dev/applications/bin/linux64GccDPOpt/icoFoam
current path :
CRITICAL ERROR
Checking networking...
Action Result Crit
Pinging_ifm-pc87 Successful yes
Pinging_localHost Successful yes
Test_rsh: Unsuccessful_connection_refused* yes
Test_ssh: Successful yes
(*) Only one of rsh or ssh is required by the OpenFOAM enviroment.
Base configuration ok.
The foam installation contains 2 critical error(s).
Review the output for warning messages and consult
the installation guide for trouble shooting.
done.
anon_c is offline   Reply With Quote
Old   August 20, 2009, 15:41
Disabled
hi the problem is solved it was my mstak thank you alot
Old   December 4, 2009, 01:33
srikara's Avatar
Srikara Mahishi
srikara is on a distinguished road
Hello Tajoooko,
I have the same problem while installing OF-1.5-dev on my suse-10.3 64bit. Could you please tell me how you solved the problem??
Thank you in advance,
Srikara
srikara is offline   Reply With Quote
k Omega SST SAS for OpenFOAM 1.5??? barath.ezhilan OpenFOAM Running, Solving & CFD 3 June 2, 2010 08:41
Modified OpenFOAM Forum Structure and New Mailing-List pete Site News & Announcements 0 June 29, 2009 06:56
OpenFOAM 1.5 installation on OpenSUSE 11.0 bigphil OpenFOAM Installation 16 April 29, 2009 07:28
Problem installing OpenFOAM 1.5 installation on RHEL 4. vwsj84 OpenFOAM Installation 4 April 23, 2009 05:48
OpenFOAM Version 1.5 Released OpenFOAM discussion board administrator OpenFOAM Announcements from ESI-OpenCFD 0 July 14, 2008 19:22
