August 19, 2009, 06:20 |
Moving Mesh with Ansa File
Hallo
I have Problem with moving mesh. I am simmulating a dynamic Problem where one Part ist moving. First I have simmulated the Problem without moving. I generated the geometry with snappyhexmesh. The Problem is that I have no idea in building the gemometry, where one imported stl File ist moving and the other will be static. I havenīt found a tutorial file that build the geometry with an stl file with a dynamic mesh. Thanks for your help |
August 20, 2009, 03:13 |
Henrik Rusche
Rep Power: 18 |
Sebastian,
in principal, the dynamic mesh motion algorithmn does not care where the mesh comes from. Just specify the velocities of the boundaries and solve for the vertex positions withing the domain. http://powerlab.fsb.hr/ped/kturbo/Op...Manuscript.pdf Of course, this has limitations when it comes to large displacements in which case you need to reconsider the initial mesh topology and/or topological changes. See here: http://powerlab.fsb.hr/ped/kturbo/Op...h_AIAA2009.pdf Henrik |
Moving Mesh Run problem - Scientific Linux | G. SE | Siemens | 2 | May 7, 2008 08:15 |
gcc and executable file from Mac to Linux | simone Marras | Main CFD Forum | 0 | April 8, 2007 16:49 |
Moving (structured) mesh | Jesper | CFX | 5 | February 2, 2007 04:43 |
Results saving in CFD | hawk | Main CFD Forum | 16 | July 21, 2005 21:51 |
How to control Minximum mesh space? | hung | FLUENT | 7 | April 18, 2005 10:38 |
